logging time and analog value on the same line
Hello,
My project is an Arduino-based noise meter, this device attempts to capture and process and then visually display amplitude changes of an analog input signal (A0 pin). Saving it to an .txt file using it later to make an excel graph.
What i expected in my .txt file:
yyyy/mm/dd,hours:minutes:seconds,Recorded value
But instead i get this:
yyyy/mm/dd
,Recorded value
I am using an Arduino UNO, an Ethernet Shield W5100, a TinyRTC I2C module and an ky-038 sound sensor
Here is my code:
#include <SPI.h>
#include <SD.h>
#include <RTClib.h>
RTC_DS1307 rtc;
const int chipSelect = 4;
const int DO = 2; // Digital PIN 2 do arduino
const int DA = A0; // Analog PIN 0 do Arduino
// Digital PIN do arduino
const int led_01 = 2;
const int led_02 = 3;
const int led_03 = 5;
const int led_04 = 6;
const int led_05 = 7;
const int led_06 = 8;
const int led_07 = 9;
 * valores do sensor (Threshold)
int sVal_01 = 500; // Initial Threshold
int sVal_02 = 508;
int sVal_03 = 512;
int sVal_04 = 516;
int sVal_05 = 520;
int sVal_06 = 524;
int sVal_07 = 528;
int lastPin = 9; // last digital PIN number
int totalLED = 7; // total LEDs
 * defenições adicionais
int debugSwitch = true;
int ledTest = true;
int sensorvalue = 0;
 * Setup
 if(! rtc.begin()) {
      Serial.println("Couldn't find RTC");
      while (1);
    else {
      // following line sets the RTC to the date & time this sketch was compiled
      rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
      Serial.println("RTC is running!");
    if(! rtc.isrunning()) {
      Serial.println("RTC is NOT running!");
  for (int i = 2; i <= lastPin; i++) {
    pinMode(i, OUTPUT);
  if (ledTest == true) {
    initTest(); // Iniciar o teste dos leds
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  delay(5000);
   // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
 for (int analogPin = 0; analogPin < 1; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 1) {
      dataString += " ";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
 DateTime now = rtc.now();
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.print(" ");
     dataFile.print(now.year(), DEC);
  dataFile.print('/');
  dataFile.print(now.month(), DEC);
  dataFile.println(now.day(), DEC);
  dataFile.print(',');
  dataFile.print(now.hour(), DEC);
  dataFile.print(':');
  dataFile.print(now.minute(), DEC);
  dataFile.println(now.second(), DEC);
  dataFile.println(dataString);
  dataFile.close();
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
  sensorvalue = analogRead(DA); // receber valores do sensor do pino A0
  if (debugSwitch == true) {
    debug();
    Serial.println("O modo debug está defeneido como falso!");
  // Lights Animation
  warenLights();
void debug() {
  Serial.print("Valor do sensor: ");
  if (sensorvalue >= sVal_01) {
    Serial.print(sensorvalue);
    Serial.println(" - LED ligado!");
    Serial.println(sensorvalue);
void initTest() { //iniciação do teste dos leds
  digitalWrite(led_01, HIGH);
  digitalWrite(led_02, HIGH);
  digitalWrite(led_03, HIGH);
  digitalWrite(led_04, HIGH);
    digitalWrite(led_05, HIGH);
   digitalWrite(led_06, HIGH);
  digitalWrite(led_07, HIGH);
delay(2000);
  digitalWrite(led_01, LOW);
  digitalWrite(led_02, LOW);
  digitalWrite(led_03, LOW);
  digitalWrite(led_04, LOW);
  digitalWrite(led_05, LOW);
  digitalWrite(led_06, LOW);
  digitalWrite(led_07, LOW);
void warenLights() {
  // Basicamente os leds irão ligar comforme o valor defenido
  if(sensorvalue >= sVal_01) {
  if(sensorvalue >= sVal_02) {
  if(sensorvalue >= sVal_03) {
  if(sensorvalue >= sVal_04) {
  if(sensorvalue >= sVal_05) {
  if(sensorvalue >= sVal_06) {
  if(sensorvalue >= sVal_07) {
Every constructive comment is appreciated :slight_smile: :slight_smile:
Part of the code that saves data:
      dataString += " ";
  if (dataFile) {
  dataFile.close();
  else {
dataFile.println() adds a line break. If you change all but the last to dataFile.print(), you will achieve your desired formatting.
Reference:
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
