Guys,
I'm looking for some Arduino based logic analyzer project. I have Mega and UNO.
Target is to analyze UART data @ 57kbps. The problem is to have >100MOhm input attenuator I guess in order to be able to use it In-Circuit.
If anyone knows such projects, please send me the link.
A long while ago I posted some proof of concept code in 'gigs and collaborations' as I needed someone to help with processing code but got no takers. I just searched for the thread and found it in 'Exhibition/Gallery' which confuses me as I don't remember posting it there.
Another thread worth looking at is this as it is meant to use an open source front end (I have never tried it myself).
See Section 20 of the 328P datasheet - set the UART of the monitoring Arduino to 57K
and just receive the data normally.
Are you sure it 57K and not 57.6K?
Monitoring serial data like that is usually done with a Protocol Analyzer, not a Logic Analyzer.
Add an appropriate buffer if you want to tap into the transmitter to be monitored without adding much load. The signal to be monitored - 0/5V? RS232 (+/-3 to +/-10 or 12?)
Riva:
It might be moved by one of the moderators as it was more a showcase than a question.
CrossRoads:
I'm not monitoring Arduino, but want to use Arduino to in-circuit monitor a device with UART.
yes, 57.6kbps it is, sorry
0-3v logic.
seems logic analyzer will do the job for me, as I can count bits. Protocol analyzer seems to be more complicated area.
Riva:
Further searching and I found the original post. I must have dumped the code in Exhibition after lack of interest and forgot I had done it (A sign of getting old)
Riva:
Riva, thanks. But is it easily extensible to 3 channels? I need to capture RX/TX/CLK...
0-3V, can read that with Arduino directly, or maybe invert it first.
Then just use regular serial commands to read it, buffer a bunch and send it to the PC or whatever:
// declare variable, pinModes, Serial.begin, etc.
int index = 0;
byte incomingArray[1000];
//then
void loop(){
if (index <1000){
if (Serial.available()>0){
incomingArray[index] = Serial.read();
index = index +1;
else {Serial.println("array full"); // TX out to PC
for (x=0; x<1000; x=x+1){
Serial.println(incomingArray[x]);
} // end loop
If you have a Mega, can monitor Rx & Tx at the same time.
If its a UART, is there even a clock to look at?
acid:
The code as it stands is no use as it's single channel but as others have said if it's standard serial data (not if it's using CLK) and you know the baud rate the arduino UART is all you need.
CrossRoads:
int index = 0;
//then
void loop(){
if (index <1000){
index = index +1;
} // end loop
Thanks for the code, got the point.
How can I increase input impedance of measuring part in order not to interfere device?
