logic function needed for touch screen buttons
i need to create some kind of logic function and merge it into my code
sorry im still learning all this and i am trying to clean up my code and get it working for my UI
at the moment i have 2 images a red button and a green button
when the program starts all buttons are off (red)
once one is pressed it will turn green then run another function to activate an electronic device
but then i want to be able to turn it off as well and then turn red
how do i keep up with what state they are in and also keep up with the state once the screen has cleared and gone on to something else. while the system is active i want it to be able to remember the state of all buttons .. but one the system is reset all buttons will be set as off
here is my screen touch code it is part of switch case as there are 5 screens i need to keep track off
case 3 is screen 3
case 3: {  // Screen 3 Active
          if ((p.x > 130 && p.x < 204) && (p.y > 213 && p.y < 276))
            oneon();
          else if ((p.x > 144 && p.x < 163) && (p.y > 280 && p.y < 320))
            twoon();
keeping in mind this is a part of a switch case how do i keep track so
If button 1 is on it will run OneOff();
but on the same touch if it is off it would run OneOn();
the button one XY limits are
at the moment the on off functions are
void oneoff() {
  // Button 1 off
  switch_off(0);
  tft.setCursor(45, 2);
  tft.setTextColor(RED);  tft.setTextSize(2);
  tft.println("Socket 1");
  bmpDraw("off.bmp", 40, 22);
void oneon() {
  // Button 1 off
  switch_on(0);
  tft.setTextColor(GREEN);  tft.setTextSize(2);
  bmpDraw("on.bmp", 40, 22);
