Logic Gate tester need help for program
Hi, I am working on logic gate (IC) tester for 74LS series. I send 00, 01, 10, 11 to 8 inputs and if 4 outputs equal than program checks the result to find which gate it is. (00 => 1, 01=> 2, 10 =>4 and 11 => 8) Program as below, and serial port always shows error or AND gate. Could you help me to improve this program. Best regards.
int gatevalue1; //Declare all of the variables
int gatevalue2;
int gatevalue3;
int gatevalue4;
int gatevalue;
int inputPin1 = 4;
int inputPin2 = 5;
int inputPin3 = 6;
int inputPin4 = 7;
int Output1Pin = 2;
int Output2Pin = 3;
int ledError = 13;
int ledAND = 12;
int ledOR = 11;
int ledNAND = 10;
int ledNOR = 9;
int ledXOR = 8;
//Begin declaring what pin is what
void setup(){
pinMode (Output1Pin, OUTPUT);
pinMode (Output2Pin, OUTPUT);
pinMode (inputPin1, INPUT);
pinMode (inputPin2, INPUT);
pinMode (inputPin3, INPUT);
pinMode (inputPin4, INPUT);
pinMode(ledError, OUTPUT);
pinMode(ledAND, OUTPUT);
pinMode(ledOR, OUTPUT);
pinMode(ledNAND, OUTPUT);
pinMode(ledNOR, OUTPUT);
pinMode(ledXOR, OUTPUT);
gatevalue = 0;
gatevalue1 = 0;
gatevalue2 = 0;
gatevalue3 = 0;
gatevalue4 = 0;
void loop(){
gatevalue1 = gatevalue1 + (check_Gate1(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue1 = gatevalue1 + (check_Gate1(false, true)*2); //and each gate will have a different gatevalue.
gatevalue1 = gatevalue1 + (check_Gate1(true, false)*4);
gatevalue1 = gatevalue1 + (check_Gate1(true, true)*8);
gatevalue2 = gatevalue2 + (check_Gate2(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue2 = gatevalue2 + (check_Gate2(false, true)*2); //and each gate will have a different gatevalue.
gatevalue2 = gatevalue2 + (check_Gate2(true, false)*4);
gatevalue2 = gatevalue2 + (check_Gate2(true, true)*8);
gatevalue3 = gatevalue3 + (check_Gate3(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue3 = gatevalue3 + (check_Gate3(false, true)*2); //and each gate will have a different gatevalue.
gatevalue3 = gatevalue3 + (check_Gate3(true, false)*4);
gatevalue3 = gatevalue3 + (check_Gate3(true, true)*8);
gatevalue4 = gatevalue4 + (check_Gate4(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue4 = gatevalue4 + (check_Gate4(false, true)*2); //and each gate will have a different gatevalue.
gatevalue4 = gatevalue4 + (check_Gate4(true, false)*4);
gatevalue4 = gatevalue4 + (check_Gate4(true, true)*8);
if(gatevalue4 == gatevalue3 && gatevalue3 == gatevalue2 && gatevalue2 == gatevalue1)
gatevalue=gatevalue4;
if(gatevalue==8)
Serial.println("The gate is an AND gate."); //When gatevalue is 1 it is an AND gate
digitalWrite(ledError, LOW); //if gate is in, light is off
digitalWrite(ledAND, HIGH);
Serial.println(gatevalue);
digitalWrite(ledOR, LOW);
digitalWrite(ledNAND, LOW);
digitalWrite(ledNOR, LOW);
digitalWrite(ledXOR, LOW);
else if(gatevalue==7)
Serial.println("The gate is an NAND gate.");
digitalWrite(ledAND, LOW);
digitalWrite(ledNAND, HIGH);
else if(gatevalue==14)
Serial.println("The gate is an OR gate.");
digitalWrite(ledOR, HIGH);
else if(gatevalue==6)
Serial.println("The gate is an XOR gate.");
digitalWrite(ledXOR, HIGH);
Serial.println("ERROR: Gate Not Present.");
digitalWrite(ledError, HIGH); //if gate is in, light is off
int check_Gate1(int output1, int output2)
int x1;
digitalWrite(Output1Pin, output1);
digitalWrite(Output2Pin, output2);
delay(5); // Make sure the signal has time to propogate through the gate.
x1 = digitalRead(inputPin1);
return x1;
int check_Gate2(int output1, int output2)
int x2;
x2 = digitalRead(inputPin2);
return x2;
int check_Gate3(int output1, int output2)
int x3;
x3 = digitalRead(inputPin3);
return x3;
int check_Gate4(int output1, int output2)
int x4;
x4 = digitalRead(inputPin4);
return x4;
Even after being asked to use code tags in your previous, identical thread you've not complied.
Why did you start a new thread?
http://forum.arduino.cc/index.php?topic=585238
void loop(){
Do you ever set gatevalue1 back to zero?
