Logic level conversion hypothetical?
I was just pondering logic level conversion for 5V Arduino to 3.3V devices. I see lots of solutions ranging from dedicated ICs to resistor voltage dividers, etc. But I haven't seen the following...
Since the Arduino (UNO) already has a regulated 3.3V pin.... Could it be possible (reliable?) to connect a transistor/FET from 3.3V pin and 3.3V device, and use the 5V signal to turn transistor/FET on/off...effectively translating the signal?
I'm curious about the feasibility of this method. Has anyone tried it? It's pretty similar to some solutions I've seen. I just havent seen anyone use the 3.3V pin as the voltage source. Is there any reason this wouldn't work?
To convert a 5V logic signal to 3.3V, you could indeed use a p-channel mosfet to connect the +3.3V pin to the input of the 3.3V device. But you would also need a pulldown resistor. A voltage divider (consisting of 2 resistors) is cheaper and simpler than a mosfet and a resistor.
You probably also could get by with using three small diodes in series to drop the 5v down to ~2.9v.
http://playground.arduino.cc/Main/I2CBi-directionalLevelShifter
Describes using mosfets.
Chagrin:
Arduino Playground - HomePage
Ok, well....I'm an idiot. :blush:
What the...how come I never find any of those Playground pages when I do searches? There's a ton of stuff very well hidden in there.
Thanks for pointing out the obvious (which I failed to see myself) to me!
1ChicagoDave:
Why not! An ordinary NPN transistor will do the job but?
If i applied 3v to the collector, 5v high to base... would the emitter spit out 3v from thr collector side or 5v from the base? Where'my android circuit emulator...
Never applied a higher voltage to it's base over the collector before!
Check out the attached image.
Yes, that will work - but it uses more components than a simple 2-resistor voltage divider.
Or this? :astonished:
Attached...
I'd still opt for a zener diode....
For an IIC level converter the only thing 'required' is 2 logic level mosfets (the lower the VGth the lower the low side voltage can be.
NXP AN10441 (attached) is a good source of 'inspiration' I've used the circuit from 5 to 3V3 (BMP085) with 2N7000's with good success. the recommended mosfet is an SOT-23 BSS138..
Level shifters of similar nature can be found on Ebay too, I bought two for $2.42 "Free Shipping".
I thought the price high considering the BOM but the convenience won me over.
Doc
AN10441.pdf (52.4 KB)
Docedison:
Doc
Ok, that's pretty clever. I like it. Thanks for posting!
https://www.google.com.au/url?sa=t&source=web&cd=1&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fdata_sheet%2FHEF4050B.pdf&ei=Tqs5Us7gIcisiAfL_IGoDw&usg=AFQjCNGXZrNtDg0e4VKIcQpSDO0B3CraRQ&sig2=VER6nJ2ByxiWc6t-K6QDhA
That link is supposed to be to the 4050 datasheet!
