Hi all,
I am trying to interface a bmp085 breakout (from Sparkfun) with an Arduino Mega. The sensor works fine with a 3.3V supply and connected straight to SDA and SCL but the trouble comes when I try to use the sensor with a logic level converter (also from sparkfun). The sensor sends the data but it’s completely wrong. I did a simple test where I turned a digital pin on and off through the logic level converter and a resistor and the voltage on the low side of the converter was around 2.2 Volts. I was expecting it to be somewhere around 3.3 V. Did I fry the logic level converter or is that within its tolerances? The only reason I’m bothering with a logic level converter is because I will need to use 5V I2C devices on the same bus.
I have included a picture of my setup
Thanks in advance for any help or advice!
