Hi, I’m trying to standardize on a couple of power FETs that are easy to drive directly from Arduino. I want one low-power easy to use, and one medium power. After digging quite a bit I found these two candidates that I can buy at a good price in Shenzhen (China):
I want these for typical hobbyist applications, and for educational kits that I build. I know there are some cool High Power FETs but that’s a different arena.
Please comment on these choices and nominate your favorites you have worked with. I’ll try to find good street prices on others if they seem better than my research!
The IRLZ34 has about the highest on-resistance for a MOSFET in its class I’ve see,
practically 0.1 ohm at logic voltages, limiting heatsink-free use to 1.5A or so.
terryking228:
Any other comments, nominations appreciated...
I've also recently started looking into this. Here are some others one could consider:
IRLZ44N - the automotive versions seem to have even lower Rds (AUIRLZ44N)
STP22NF03L
IRLB8748PbF
IRLZ44N - Nice… …025 ohms at 5V and I can find it at a good price in China, sell for 75 cents or so…
STP22NF03L Nice. Low RDson Also good price
IRLB8748PbF Nice again, VERY low RDSon at .005 ohms 4.5V
I can find those 3 at the good price (usually 2.5 to 3.0 RMB) in Shenzhen, China from suppliers I do some business with. So can sell at 75 cents to a dollar and be worth handling. Not a big part of Arduino business but an area I want to cover.
Now: IsThere a better device in TO92 or other small case that is better than the ZVN4206 which is pretty oldskool?
BTW, the easiest best Data Sheet place I’ve found is http://www.datasheets.com/ You need to make a login but no hassles from them.
AND I’m concerned about ESD, both from just dropping them into those Harbor Freight plastic boxes, and from students picking them up and plugging them into breadboards. So I’m looking at the RFP30N06LE specifically for it’s ESD protection. The gate oxides on ALL of these are pretty thin!
Installed in a PCB with care about ESD they’re AllGood. But the the classroom, maybe Trouble. Anyone have experience with this?
Static protection is a tricky one - the main precaution is one you have no control over,
namely to ban nylon carpets. I think the best you can do is to provide black conducive
foam packaging (the sort you stick the legs into) and prominent warning stickers.
Power MOSFETs have a lot of capacitance which helps protect the gate from small amounts
of charge.
