Logic Levels into the OPTA
we have a 5v input from a Push Button Wired to A4 on the OPTA in which it does not recognize the Logic Level at all , it only see's a Logic Level when we Move it to 24v through the push-button. it says the logic level is 0 to 24V in the Documentation, is there Something i have to Setup. ?
Hi, i will try to help you!
In this moment i don't know your circuit configuration, but probably you need a pull down resistor on the input, a 10K resistor to connect the pin to the ground should be fine, or maybe the problem is the value of the logic level used by the OPTA.
I hope you can solve your problem!
"24V logic" means that logic 1 is 24V, logic 0 is 0V.
The Opta data sheet should tell you where the intermediate cutoffs are.
