I am testing timers of Due. At first I tested wave mode with following sketch:
#include <Arduino.h>
volatile uint32_t tm=0, cntval=0;
Serial.begin(19200);
PMC->PMC_PCER1 |= PMC_PCER1_PID32; // activate clock for Timer5
PIOB->PIO_ABSR &= !PIO_ABSR_P16; // Switch the multiplexer on pin PB16 to peripheral A for TCLK5
PIOB->PIO_PDR |= PIO_PDR_P16; // Disable the GPIO on PB16
TC1->TC_BMR = TC_BMR_TC2XC2S_TCLK2; // TCLK5 on XC2
TC1->TC_CHANNEL[2].TC_CMR = TC_CMR_TCCLKS_XC2; // external clock on XC2
TC1->TC_CHANNEL[2].TC_CMR |= TC_CMR_WAVE; // wave mode
TC1->TC_CHANNEL[2].TC_CCR = TC_CCR_CLKEN | TC_CCR_SWTRG; // enable clock and trigger counter
tm=millis();
if (millis()-tm > 300) {
uint32_t cntact=TC1->TC_CHANNEL[2].TC_CV;
Serial.print(" -> "); Serial.print(cntact);
Serial.print(" delt="); Serial.println(cntact-cntval);
cntval=cntact;
tm=millis();
On pin D67 which also is DAC1 a function generator is connected. On Serial Monitor I can see the counter of Timer5 running up according to the set frequency.
Then I changed the line
to
TC1->TC_CHANNEL[2].TC_CMR &= !TC_CMR_WAVE; // capture mode
and expected to see the same counter values.
But really the counter was running up as if the function generator would send 42 MHz. Indeed for a short time unintentionally I had set the amplitude of the function generator to 5V which can damage internals of the Due. And I was afraid of that.
But the timer5 still works
TC_CMR_WAVE is a define:
#define TC_CMR_WAVE (0x1u << 15)
but !TC_CMR_WAVE != !(0x1u << 15) but 0
I am happy that my timer is ok, but I don't understand why !TC_CMR_WAVE=0.
What is the explanation?
