Logique du DS3231 et essais
Bonjour,
Je viens d'acquérir un DS3231 et j'ai un peu de mal à comprendre le fonctionnement.
J'utilise un exemple de code de la librairie RTClib comme suivant :
Code injecté pour définir la date :
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
#include "RTClib.h"
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
Serial.begin(57600);
if (! rtc.begin())
Serial.println("Couldn't find RTC");
Serial.flush();
while (1) delay(10);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
Serial.println("Set time");
void loop () {
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
delay(3000);
Code injecté après le précédent code pour lire la date et l'heure :
#include "RTClib.h"
RTC_DS3231 rtc;
void setup () {
if (! rtc.begin())
Serial.flush();
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
//Serial.println("Set time");
void loop () {
Serial.print('/');
Serial.print('/');
Serial.print(" (");
Serial.print(") ");
Serial.print(':');
Serial.print(':');
delay(3000);
Résultat :
13:01:38.809 ->
13:01:41.794 -> 2022/11/23 (Wednesday) 13:1:35
13:01:41.794 ->
13:01:44.813 -> 2022/11/23 (Wednesday) 13:1:38
13:01:44.813 ->
13:01:47.810 -> 2022/11/23 (Wednesday) 13:1:41
13:01:47.810 ->
13:01:50.804 -> 2022/11/23 (Wednesday) 13:1:44
13:01:50.804 ->
INJECTION NOUVEAU CODE
13:02:05.459 -> 2000/1/1 (Saturday) 0:0:3
13:02:05.459 ->
13:02:08.470 -> 2000/1/1 (Saturday) 0:0:6
13:02:08.470 ->
13:02:11.471 -> 2000/1/1 (Saturday) 0:0:9
13:02:11.471 ->
13:02:14.442 -> 2000/1/1 (Saturday) 0:0:12
13:02:14.476 ->
13:02:17.470 -> 2000/1/1 (Saturday) 0:0:15
Ici je comprend que le module ne retient pas la date alors que dans le second code je ne fais que la lire ! Autrement dit le module il est impératif de donner la date ou module RTC après chaque coupure de courant ?!?
Autre bout de code qui ne fonctionne pas :
#include "RTClib.h"
RTC_DS3231 rtc;
void setup () {
if (! rtc.begin())
Serial.flush();
if (rtc.lostPower()) {
Serial.println("RTC lost power, let's set the time!");
// Wh
en time needs to be set on a new device, or after a power loss, the
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(DATE), F(TIME)));
void loop () {
Serial.print('/');
Serial.print('/');
Serial.print(" (");
Serial.print(") ");
Serial.print(':');
Serial.print(':');
delay(3000);
Avec comme résultat :
13:17:25.043 -> 2022/11/23 (Wednesday) 13:17:20
13:17:25.077 ->
13:17:28.067 -> 2022/11/23 (Wednesday) 13:17:23
13:17:28.067 ->
13:17:31.075 -> 2022/11/23 (Wednesday) 13:17:26
13:17:31.075 ->
13:17:34.073 -> 2022/11/23 (Wednesday) 13:17:29
13:17:34.073 ->
DEBRANCHEMENT & REBRANCHEMENT
13:17:46.414 -> 2022/11/23 (Wednesday) 13:17:17
13:17:46.447 ->
13:17:49.430 -> 2022/11/23 (Wednesday) 13:17:20
13:17:49.430 ->
13:17:52.428 -> 2022/11/23 (Wednesday) 13:17:23
13:17:52.428 ->
Clairement, après débranchement on voit que la date repart au moment de la compilation.
Je pense que je fais ou que je comprends quelque chose de mal, un idée de quoi ?
Mon module DS 3231 serait-il défaillant ?
Le module a bien une batterie ou une pile?
Si c'est une batterie, est-elle bien chargée?
Vérifier au voltmètre, aux bornes de la batterie (ou de la pile) lorsque le module n'est pas alimenté par l'Arduino. Quelques fois les modules venant de Chine se retrouvent avec une batterie complètement déchargée et il faut un certain temps pour que celle-ci se recharge.
Bonjour Keisar
La version du sketch dans ton Arduino a, sûrement, la ligne ci-dessus, active.
Cordialement
jpbbricole
Il serait étonnant que ton dernier sketch donne un résultat quelconque, avec une accolade manquante à la fin de setup().
Note : utilise les balises code (preformatted text) au lieu de blockquote, ce sera plus lisible.
Alors vous allez rire mais j'avais un doute sur la pile livrée avec le module et j'ai directement changé la pile. Figurez vous que Duracell colle un petit sticker sur le dessous de la pile.
Bref, sans le Sticker le contact se fait et ça fonctionne...
Cela doit être exigé dans le transport.
Bonjour,
Ce n'est pas Duracel, mais le fabricant du module.
C'est courant, c'est pour que la pile ne se décharge pas pendant le stockage et le transport. Souvent c'est une petite languette en plastique qu'il faut tirer à la mise en service.
