Logitech TrackMan Marble FX USB converter
Hi guys.
I made a simple PS/2 logitech trackball to USB converter using arduino micro.
It is based on ps2mouse(Arduino Playground - Ps2mouse).
Virutal wheel function added for my convenience.
Any suggestions or comments welcomed.
Thanks.
sketch_dec12b.ino (6.59 KB)
So, I Realize this post is 2 years old, but I tried this out on a CJMCU Beetle (not to be confused with the DFRobot Beetle) and it, well, does not work.
I guess my next step is to figure out how to re-program the 32u4. The only things i changed were the pin numbers, since the 5 and 6 aren't brought out to through-holes on the Beetle. Maybe the pin assignment is different on the (allegedly leonardo compatible) beetle than the micro.
Has anyone else used this project?
quick update - found a Micro and breadboarded this. Seems to work fine.
I don't see any outputs on the serial console though?
On one of my marbles i can't scroll, but that could be a bad switch.
Mouse switches are easily acquired on eBay these days so maybe i will just replace it and see.
4 years late here.
Thank you very much for this sketch!
I've made a few changes to it: GitHub - dkao/Logitech_Trackman_Marble_FX_PS2_to_USB_converter: PS/2 to USB converter using Logitech's PS2++ extension
  • Changed to PS/2 stream mode with up to 200Hz sample rate
  • Red button as back button instead of scroll button, I use this with software wheel emulation
