Lolin D1 Mini Pro with 16MB flash / esp8266fs SPIFFS upload tool / Bad upload
I'm using a (genuine) Wemos Lolin D1 Mini Pro with 16MB flash and am having extreme difficulty loading a set of 4 files (windows reports 2.02 MB total size) into it's SPIFFS files system using the ide add-in tool esp8266fs-plugin (ver 0.3.0). I'm using the arduino esp core version 2.4.1.
The symptoms are that the the sketch which attempts to list the files found in the SPIFFS file system either (a) finds only one of the files in the set or (b) for some reason, there is a long pause during the SPIFFS.begin() phase where it is presumably reformatting the file system and, of course, then reports an empty file system.
I've also tried loading the sketch with "Erase All Flash Contents" option to clean things out and have tried using a SPIFFS.format() statement in the sketch but neither has helped.
Here is the output from the esp8266fs:
[SPIFFS] data : C:\Users\6v6gt\Documents\Arduino\ESP8266\spiffs_test-Aide_v0.02\data
[SPIFFS] size : 15340
[SPIFFS] page : 256
[SPIFFS] block : 8192
/RenateFuczik_v0.03.b.trk
/RenateFuczik_v0.03.wav
/text1.txt
/text2.txt
[SPIFFS] upload : C:\Users\6v6gt\AppData\Local\Temp\arduino_build_964227/spiffs_test-Aide_v0.02.spiffs.bin
[SPIFFS] address: 0x100000
[SPIFFS] reset : nodemcu
[SPIFFS] port : COM7
[SPIFFS] speed : 256000
Uploading 15708160 bytes from C:\Users\6v6gt\AppData\Local\Temp\arduino_build_964227/spiffs_test-Aide_v0.02.spiffs.bin to flash at 0x00100000
................................................................................ [ 0% ]
................................................................................ [ 1% ]
etc. etc.
............................................................ [ 100% ]
It looks OK. I have 15M SPIFFS selected in the boards properties. The size of the image it has built looks OK (15708160) which is the difference between the spiffs_start (0x100000) and spiffs_end (0xFFB000) determined from the boards.txt file.
The sketch which I run is here :
based on: https://circuits4you.com/2018/01/31/example-of-esp8266-flash-file-system-spiffs/
ESP8266 SPIFFS Basic Reading and Writing File
v0.02 16MB test
#include <ESP8266WiFi.h>
#include <FS.h> //Include File System Headers
// stop attempts to build wifi connection
WiFi.disconnect();
WiFi.mode(WIFI_OFF);
delay(1000) ;
//Initialize File System
Serial.println("SPIFFS.begin() . . . ");
if (SPIFFS.begin())
Serial.println("SPIFFS Initialize....ok");
Serial.println("SPIFFS Initialization...failed");
//Format File System
#if 0 // commented out to endif !!
Serial.println("SPIFFS.format() . . . ");
if (SPIFFS.format())
Serial.println("File System Formated");
Serial.println("File System Formatting Error");
#endif
struct FSInfo {
size_t totalBytes;
size_t usedBytes;
size_t blockSize;
size_t pageSize;
size_t maxOpenFiles;
size_t maxPathLength;
Serial.println(F("SPIFFS filesystem. Info"));
FSInfo fs_info;
SPIFFS.info(fs_info);
Serial.printf( "Tot: (%d), Used: (%d), block: (%d), page: (%d), maxOpen: (%d), maxPath: (%d) \r\n",
fs_info.totalBytes , fs_info.usedBytes , fs_info.blockSize , fs_info.pageSize , fs_info.maxOpenFiles , fs_info.maxPathLength ) ;
delay(1000) ;
Dir dir ;
Serial.println(F("SPIFFS filesystem. Dumping directory ..."));
dir = SPIFFS.openDir("/");
while (dir.next()) {
String str = "" ;
// fn = String( dir.fileName() ) ;
str += dir.fileName();
str += " / ";
str += dir.fileSize();
str += "\r\n";
Serial.print(str);
Serial.println() ;
Serial.println("end of setup()");
Serial.println("in loop()" ) ;
delay(2000) ;
and delivers this output (in the case where one of the four files is found) :
Tot: (14900866), Used: (1823515), block: (8192), page: (256), maxOpen: (5), maxPath: (32)
/RenateFuczik_v0.03.b.trk / 2580
end of setup()
in loop()
in loop()
etc. etc.
In the the other case, there is a long wait (minutes) at the SPIFFS.begin() stage.
The only odd thing I see in the output is the total size of the SPIFFS file system reported by the sketch is significantly smaller than the size of the image loaded by the esp8266fs tool.
This effect seems to be independent of the upload speed.
Any ideas on how to trouble shoot this ?
Edit. If I select a board file for the equivalent device with only 4MB of flash, it works fine, but that is no solution as I require more than 3MB of SPIFFS.
