I'm completely new with Arduino and everything to do with micro controllers. I did a little research, but for the project I'm planning to go with I think I need some help. First, where could I learn more about Arduino and Coding it seems quite complicated from the skill level I'm at. Just where to start?
I'm planning on using a hall sensor or a magnetic relay switch to read rpm off a Long Board wheel to feed into the Arduino uno. then having the Arduino calculate RPM, Speed, Max Speed and Distance Traveled. But also to make this project a little more complicated or practical, I want to connect the Arduino uno mounted on my Long board communicate via xbee either to the other xbee to a 16.2 handheld lcd or if neccesary a arduino pro mini then the lcd.
I'm aware this project may seem a little far fetched, especially with my skill level ;D, but I'm pretty determined to do this project. And suggestions/help would be amazing.
Thanks.
