long data / Serial.print
Folks
when I send
long l = 123456;
Serial.print(l);
to a Python script I have to read 6 (count of numbers) bytes instead of 4 (size in byte of data type long)
print ser.read(6)
so it looks Serial.print send every single number as a byte instead the correct 4 bytes.
Is there a option to choose or do I have to take care of this my self?
Thanks!
Serial.print formats the number into a series of ASCII characters and sends those. Use serial.write to send binary data.
Thanks
long l = 135274560;
Serial.write(l);
Serial.write(l >> 7);
Serial.write(l >> 14);
Serial.write(l >> 21);
or
for (int i=0;i<sizeof(l);i++){
  Serial.write(l >> i*7);
is there a better way?
That won't work. Why would you shift by 7?
Try Serial.write(&l, 4);
That won't work.
Actually it does.
I don't know. I think it should be shifted by 8. But then it doesn't work.
error:
no matching function for call to 'HardwareSerial::write(long int*, int)'
So, cast it.
how?
Serial.write ((char *)&l, 4); //or perhaps (byte *)
Great, it works
Thank you!
