I am using a SparkFun Venus GPS with SMA Connector in my project with following code:
#include <SoftwareSerial.h>
SoftwareSerial gpsSerial(10, 11); // RX, TX (TX not used)
const int sentenceSize = 80;
char sentence[sentenceSize];
gpsSerial.begin(9600);
static int j= 0;
if (gpsSerial.available())
char ch = gpsSerial.read();
if (ch != '\n' && j< sentenceSize)
sentence[j] = ch;
j++;
sentence[j] = '\0';
j= 0;
displayGPS();
void displayGPS()
char field[20];
getField(field, 0);
if (strcmp(field, "$GPRMC") == 0)
Serial.print(" Time: ");
getField(field, 1); // number
Serial.print(field);
Serial.print(" Validity: ");
getField(field, 2); // number
Serial.print(" Lat: ");
getField(field, 3); // number
getField(field, 4); // N/S
Serial.print(" Long: ");
getField(field, 5); // number
getField(field, 6); // E/W
Serial.print(" Speed: ");
getField(field, 7); // number
double veh_spd=atoi(field)*1.852;
Serial.print(field); //speed in knot
Serial.print(" km/h: ");
Serial.print(veh_spd);
if (strcmp(field, "$GPGGA") == 0)
Serial.print(" Alt: ");
getField(field, 9); // number
double Alt=atoi(field);
Serial.println(field);
void getField(char* buffer, int index)
int sentencePos = 0;
int fieldPos = 0;
int commaCount = 0;
while (sentencePos < sentenceSize)
if (sentence[sentencePos] == ',')
commaCount ++;
sentencePos ++;
if (commaCount == index)
buffer[fieldPos] = sentence[sentencePos];
fieldPos ++;
sentencePos ++;
buffer[fieldPos] = '\0';
The GPS works fine, but when I tested it in my car I noticed a very long delay (about 4 seconds) in the speed comparing with actual speed of the car (I am assuming location has the same delay).
Is this issue caused by the wrong code or it’s a hardware problem?
Thanks
