Long distance IR signal using 1-3 IR LED
Can any one tell me how to increase the distance of IR signal like syma remote control. I can use 3 IR LED in serial and a npn (2n2222) transistor. Before output pin voltage connect to the base of the transistor I used 100ohm resistor. Can any one tell me how to increase the distance over 100 ft. Or is it possible or not? Thanks in advance for your help.
sakilimtiaz:
Yes, it's possible to get range of 100 ft or even 100 meters but it's probably not as easy as adding a couple extra IR LEDs.
You'll likely need to use laser tag setups.
Here are some links on the topic.
WowWee Light Strike Hack
https://forum.arduino.cc/index.php?topic=369431.0
Miles Tag System
Using extra LEd could get a range of 100 M easily but not with a wide beam angle.
Used to use this method with optics for beam break security detectors.
Passe now.
For remote , they normally have large beam angle and limited range.
Optics can sort that but you have to be accurate with pointing.
There are also narrow beam IR LEDs.
I have used the SFH400 with integrated glass lens, but the beam might be too narrow for a handheld remote.
Leo..
Thanks every one for your kind feed back. I am following your suggestion. I will let you know what happens next.
Unless you use good optics, you'll have to quadruple IR power fro double the range. For long
range a lens system is the way to go, but you only get point-to-point, not broadcast or course.
