Long & Short Press Push button on/off with 1 minutes delay
I programmed to press the push button once ( long press ) to turn on the LED in the board and press it again (short press) to turn off.
But i need help,
If i push button (short press or long press) no action taken care by program withing 1 minutes after LED on
same case after LED off.
Code Below
int LED1 = 12;
int LED2 = 13;
int button = 3;
boolean LED1State = false;
boolean LED2State = false;
long buttonTimer = 0;
long longPressTime = 250;
boolean buttonActive = false;
boolean longPressActive = false;
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(button, INPUT);
if (digitalRead(button) == HIGH) {
if (buttonActive == false) {
buttonActive = true;
buttonTimer = millis();
if ((millis() - buttonTimer > longPressTime) && (longPressActive == false)) {
longPressActive = true;
LED1State = !LED1State;
digitalWrite(LED1, LED1State);
if (buttonActive == true) {
if (longPressActive == true) {
LED2State = !LED2State;
digitalWrite(LED2, LED2State);
How is your switch wired?
This should be:
unsigned long buttonTimer = 0;
The code for different button presses in this link may be helpful
...R
