Long term logging with micro SD into different files
I have a project where I want to store individual data from five analog inputs in separate files – i.e. one file per analog input. I also want to map the time for each data point (I’ll be logging continuously for 3 months). I’m using IR diode pairs to record rotations of a clear object. The object has one opaque band on it. Each time the band passes the diode pair, I can record a voltage change.
My problem is that I’m new to Arduino code and the logging aspect is beyond me at my current skill. I have no idea how to code in reading and writing functionality.
Here is what my code looks like: (Note: some of the serial.print commands are there for when I use PLX DAQ in conjunction with the Arduino)
  Serial.println("CLEARSHEET");
  Serial.println("LABEL, CageOneVoltage, CageTwoVoltage, CageThreeVoltage");
        //int aVal = analogRead(A0);
//FOR CAGE ONE
        unsigned int CageOneVoltage;                    //A0
        double Voltage;
        double Vcc;
        Vcc = readVcc()/1000.0;
        CageOneVoltage = analogRead(A0);
        delay(10);
          Voltage = (CageOneVoltage / 1024.0) * Vcc;
//FOR CAGE TWO
        unsigned int CageTwoVoltage;                    //A1
        CageTwoVoltage = analogRead(A1);
        delay(10);
          Voltage = (CageTwoVoltage / 1024.0) * Vcc;
//FOR CAGE THREE
        unsigned int CageThreeVoltage;                  //A2
        CageThreeVoltage = analogRead(A2);
        delay(10);
          Voltage = (CageThreeVoltage / 1024.0) * Vcc;
//FOR CAGE FOUR
        unsigned int CageFourVoltage;                   //A3
        CageFourVoltage = analogRead(A3);
          Voltage = (CageFourVoltage / 1024.0) * Vcc;
//FOR CAGE FIVE
        unsigned int CageFiveVoltage;                   //A4
        CageFiveVoltage = analogRead(A4);
          Voltage = (CageFiveVoltage / 1024.0) * Vcc;
//CAGE ONE PRINT
        Serial.print("CAGEONE");                //Readout for A0
        Serial.print(",");
        Serial.println(CageOneVoltage);
//CAGE TWO PRINT
        Serial.print("CAGETWO");                //Readout for A1
        Serial.print(",");
        Serial.println(CageTwoVoltage);
//CAGE THREE PRINT
        Serial.print("CAGETHREE");              //Readout for A2
        Serial.print(",");
        Serial.println(CageThreeVoltage);
//CAGE FOUR PRINT
        Serial.print("CAGEFOUR");               //Readout for A3
        Serial.print(",");
        Serial.println(CageFourVoltage);
//CAGE FIVE PRINT
        Serial.print("CAGEFIVE");               //Readout for A4
        Serial.print(",");
        Serial.println(CageFiveVoltage);
long readVcc() {
  long result;
  // Read 1.1V reference against AVcc
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result =1135200L / result; //1149852L / result; // Back-calculate AVcc in mV
  return result;
I don’t need anything complicated, I just need to ensure that I can record all of my data without any crashes. By the way once I have the data, I’ll determine the average threshold and convert all values within a certain standard deviation of the threshold to 0’s and the rest to 1’s. I’ll then just sum up all the ones and determine how many rotations over a period of time.
One last question, for how long do you think a 16GB micro SD could record this data? I plan to remove the micro SD cards weekly to compile the data. Perhaps daily if that would be recommended.
Thanks in advance!
I can’t offer much help, but notice you did not disclose the most critical information: How often do you record and How much data in each record.
Paul
Dwood1003:
I have a project where I want to store individual data from five analog inputs in separate files -- i.e. one file per analog input...
It is far from clear why you would want to do this, and it is an approach you are likely to regret but, if you close the file after recording data, always good practice anyway, you can then open a different file to record the next item.
.The object has one opaque band on it. Each time the band passes the diode pair, I can record a voltage change............. I'll determine the average threshold and convert all values within a certain standard deviation of the threshold to 0's and the rest to 1's. I'll then just sum up all the ones and determine how many rotations over a period of time.
This may be a matter better solved digitally than anlogue in the first place
in view of the deafening silence on the little matter of the rate of data accumulation but in the light of the 16Gb, the only answer is - probably a lot longer than you think.
