Long transmittion delay issue.
Hello everyone. im rather new to the Arduino and im trying to use a Transmitter and a receiver to turn an Led on while a button is pushed down. it seems to work but with a small issue, there is a noticeable transmitting delay. around 0.30 seconds or so. is that normal?
here is my Code:
Transmitter:
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
int Pin10_Led = 12;
int BUTTON_4=4;
RH_ASK driver(2000, 8, 8, 5);
pinMode(BUTTON_4,INPUT);
pinMode(Pin10_Led,OUTPUT);
Serial.begin(9600); // Debugging only
if (!driver.init())
//RH_HAVE_SERIAL
Serial.println(“init failed”);
if(digitalRead(BUTTON_4)==HIGH){
Serial.println(“on”);
const char *msg = “4”;
driver.send( (uint8_t*)msg,strlen(msg));
driver.waitPacketSent();
{ const char *msg = “1”;
Reciever :
#include <RH_ASK.h>
int Pin10_Led = 12;
int BUTTON_4=4;
if (!driver.init())
//RH_HAVE_SERIAL
Edit your post and insert code tags!
int Pin10_Led = 12;
That's more than a strange name for the variable.
I didn't check every character but the two codes for sender and receiver look identical to me.
