LONG Wire bme280 pullup resistors and clock speed question
I have an Arduino Uno R3 and was using the I2C tabs on the board located here to chat with this BME280. The setup I'm using is pretty sweet and have two TRRS 3.5mm audio cables (4 wires) one in male the other in female. Each of those guys are 6' long. So we're talking 12 feet length with a plug in the middle. I chose to use 5v instead of the called for 3.3v due to the cable length. (Tried it on the breadboard and 5v worked fine). I've been doing some reading on this but seems the online debates are actually just making me more confused. And I may be over complicating this. Anyway..
The issue I'm having is during the setup the LCD freezes and goes blank when the MCU tries to call the sensor. Obviously those built in pull ups just aren't enough (or too much actually). The part Im getting confused about is I've read I can disable the built-in resistors with something like:
digitalWrite(SDA, 0);
digitalWrite(SCL, 0);
directly after the "status = bme.begin(0x76);" and then drop 2 1kohm's on those scl&sda tabs? Is this correct or do I have to use a different set of pins. Im using a LCD shield in this project so I'd prefer not to use different pins if I can get away with it. Finally I was curious about my clock speed. Do I need to turn down my clock speed with:
wire.setClock(10000);
as well as changing the pullup values??
My code (just in case):
/* Temperature controlled relay using a BME280 sensor and a SainSmart 16x2 LCD w/ Keypad
    The key pad has all buttons tied to A0 with different resistence values on each button to call the desired character
      Programmed by Jerimy
#include <DFR_LCD_Keypad.h> //simply has keypad resistance limits
#include <Wire.h>
#include <LiquidCrystal.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define RELAY  13  // Relay for the A/C unit
#define ALTITUDE 191.0 // Altitude of Brownsville MD  (my town)
int last_key, key;
float setTemp = 74.5; //default temperature so it doesn't start at zero when changing temps
int val = 0; //The value to test our keypad resistence value
const int redLED = 12; // red LED A/C is on
const int greenLED = 11; // green LED A/C is off
float temperature;
float humidity;
float pressure;
Adafruit_BME280 bme; // I2C
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
DFR_LCD_Keypad keypad(A0, &lcd);
  lcd.begin(16, 2);
  lcd.setCursor(0, 0);
  lcd.print("Big Bud Sys By:");
  lcd.setCursor(0, 1);
  lcd.print("DNozz");
  delay(2000);
  lcd.clear(); //clear the screen
  lcd.print("Reading Sensors");
  bool status;
  delay(2000);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(greenLED, HIGH); //Green LED On
  digitalWrite(redLED, LOW);    //Red LED Off
  digitalWrite(RELAY, LOW);      //Turn off Relay
  status = bme.begin(0x76);  //The I2C address of the sensor I use is 0x76
  // if m.controller can't "find" the sensor at address 0x76
  if (!status) {
    lcd.print("check wiring");
    Serial.println("Can't find the BME280 sensor, check wiring!");
    while (1);
  if (status) {
    lcd.print("Sensor Working");
    Serial.println("Sensor is Working");
    delay(1500);
  lcd.clear();
  lcd.print("Up & Down change");
  lcd.print("the temperature");
  delay(3000);
  lcd.clear();
  lcd.print("Left - On");
  lcd.print("Right - OFF");
  delay(3000);
  lcd.clear();
  lcd.print("Hit select for");
  lcd.print("Humid. & Pres.");
  delay(3000);
  lcd.clear();
void loop()     {
  //val = analogRead(0); // read the value from the sensor connected to A0.
  //Serial.println(val); //Prints the value coming in from the analog sensor for testing.
  getPressure();
  getHumidity();
  getTemperature();
  // Controls the relay and LEDs based on the set temperature
  if (temperature >= setTemp)  {
    digitalWrite(RELAY, HIGH);  {
      digitalWrite(redLED, HIGH);
      digitalWrite(greenLED, LOW);
      //      while (setTemp - temperature < 1) {   //THIS IS WHERE I NEED HELP!!!       want to A/C to cool 4 degrees past the set temp to avoid repeated on and off.
      //        digitalWrite(RELAY, HIGH);          // This while statement doesnt work at all!!
      //        digitalWrite(greenLED, HIGH);
  if (temperature <= setTemp - 2)  {
  // General display of current sensor readings
  String temperatureString = String(temperature, 1);
  lcd.print("Temp: ");
  lcd.print(temperatureString);
  lcd.print((char)223);
  lcd.print("F ");
  lcd.print("Set Temp= ");
  lcd.print(setTemp, 1);
  lcd.print("F ");
  //looking for changes on A0 (button presses)
  last_key = keypad.get_last_key();
  key      = keypad.read_key();
  if (key != last_key) {      // a button was pushed!
    lcd.clear();
    switch (key) {
      case KEY_UP:  {
          setTemp += 0.1;
          //lcd.print("Temp Set to: ");
          //lcd.print(setTemp);
          //delay(800);
      case KEY_DOWN:  {
          setTemp -= 0.1;
          //delay(800);
      case KEY_SELECT:  {
          String humidityString = String(humidity, 0);
          lcd.print("Hum: ");
          lcd.print(humidityString);
          lcd.print("%");
          lcd.print("Prs: ");
          String pressureString = String(pressure, 2);
          lcd.print(pressureString);
          lcd.print(" hPa");
          delay(5000);
      case KEY_LEFT:  {
            lcd.print("Cooling ON");
            delay(800);
      case KEY_RIGHT:  {
          digitalWrite(RELAY, LOW);  {
            lcd.print("Cooling OFF");
            delay(800);
// This is the BME280 setup stuff and believe it has to be outside the loop brackets or it
// throws an error on line 80 "getPressure was not declared in scope"
float getTemperature()
  temperature = bme.readTemperature();
  temperature = Celcius2Fahrenheit(temperature);
float getHumidity()
  humidity = bme.readHumidity();
float getPressure()
  pressure = bme.readPressure();
  pressure = bme.seaLevelForAltitude(ALTITUDE, pressure);
  pressure = pressure / 100.0F;
float Celcius2Fahrenheit(float celsius)
  return celsius * 9 / 5 + 32;
The built-in pull-up resistor value are probably too high, so don't pull up strongly enough. Lower value resistors would pull up more strongly. You may well find the sensor and LCD boards also have pull-ups built in, but often these are around 10K, so also a little weak. Leave the built in pull ups alone and add extra 4K7 or 3K3 to the lines. Lowering the clock speed might also be helpful.
But wouldn't adding resistance to the current resistors just make it worse? (Why I thought I had to disable the built in guys and go with a new lower value so that total resistance is less than it currently is).
Wait.. Adding resistors would effectively be in parallel with the built in's right? So would lower resistance not add to it. 1/r1 + 1/r2 = 1/rT.. So what was all that jazz about disabling the built in resistors on the board?
Sometimes you can get the opposite problem: pull-up resistors too string (low combined resistance) especially if there are many devices on the bus. But with only 2 devices and long wires, unlikely that's the problem.
