Longer life expectancy for my circulation pump setup?
Paul,
The man said 'peristaltic' pumps. Like in dialysis machines, printers, dosing pumps etc etc. Sadly, they are not typically intended for use as fast or high volume pumps.
OP,
I can only think that a centrifugal pump / impeller pump with a clearance between impellers and housing would be the way to go. These are the usual pumps for bilge and general purpose and I have seen these with maximum particulate sizes up to 3mm or more. But now I am assuming things about your application and answering my own assumptions which may not be helpful. So if you can fill me in; how much water do you need to move? How far? How high? Particulate size? Nature of contaminates? (acidic/alkaline?) Impeller pumps can be a bit violent, is that an issue? Impeller pumps are also not self priming, is that an issue?
PE
