looking for 4-20mA current driver controlled by arduino
Hello,
I'm working with a VFD which use 4-20mA at analoge input as frequency set-point.
I want to change this set-point by 4-20mA current driver controlled by arduino board.
Note - It has to be OTS item.
any advice?
thanks a lot,
uv12b
I'd like to help you, but don't understand, as I'm new n arduino and don't know what be OTS item is. is something like this?
Off The Shelf.
so if i understand you correctly, you want a device that can control how much current goes out? like a current limiter?
Check:
http://www.ti.com/lit/ds/symlink/xtr117.pdf
Digi-Key should have it.
Or, for digital input:
http://www.analog.com/media/en/technical-documentation/data-sheets/AD421.pdf
DMond:
4..20mA is a totally industry standard analog control signal, normally at 24V, there will be
off the shelf units, the OP is asking for such.
What model VSD is it?
Tom..... :slight_smile:
Plenty of 4-20mA voltage to current modules on ebay.
http://www.ebay.com/itm/Voltage-to-Current-Module-0-3-3V-turn-4-20mA-Conversion-sensor-/311390802245?pt=LH_DefaultDomain_0&hash=item4880569145
Leo..
Google Search: Arduino 4-20 mA shield
User Manual
Nice find, but that is input only. It's a data logger. The OP wants output.
Maxim does some SPI to 4-20ma chips. That seems to package all the required components into one chip.
Ready built there is this:-
dac161s997 16bit-dac-eval-board
