Looking for a 4 position switch
Glade and other companies make these automatic air fresheners that have a 4 position switch.
1 off
2 low
3 medium
4 high
How can I duplicate this with an arduino? Is there a switch avaiable that can duplicate this? Obviously I would have to have the battery hooked up to this, in addition being able to read position 2-3.
[u]Here[/u] is an example of a 4-position rotary switch. A multi-position rotary switch is easier to find than a multi-position slide switch. You can also find rotary switches with an adjustable stop, so they might have 10 or 11 positions, but they can be adjusted-down to fewer positions.
Or... Once you've got a programmable microcontroller, it's possible to use a single button that cycles-through the functions/variables (maybe with 3 LEDs to indicate low, med, high), or an "up" button and a "down" button, or 3 separate speed buttons, and an on-off-switch, etc.
Something like this?
Left is probably off, then pin one connects to 2,3,4 if you keep sliding to the right.
You might like to consider something like this.
It has a total of 12 positions, but there is an adjustable end stop (it's hidden underneath the mounting nut), that enables you to select anything between 2 and 12 positions,
One basic switch can be re-configured to be many different 'ways'.
liudr:
1825161-2 TE Connectivity ALCOSWITCH Switches | Switches | DigiKey
How can you tell left is off? The datasheet doesn't really say. Can anyone make sense of this?
Since you're looking for a 4 position switch, its the SP4T version shown. Terminal 3 is common, from left to right it switches 1-3, 2-3, 3-4, 3-5.
Note that its specified as MAKE-BEFORE-BREAK.
What this means is there is never any "open" state as the switch is moved from left to right and there are 2 terminals shorted to common in between positions. Here, I've added the in between states to show what happens (left to right):
POS1          POS2          POS3          POS4
1-3   1-3-2   2-3   2-3-4   3-4   4-3-5   3-5
