Hello everyone,
I am looking for a pressure sensor, similar to "Intersema MS5212BZ". The only characteristics I interested in are:
- It has to be analog output
- Working pressure 0..12 bar, with the best possible resolution (ideally 1/10 bar or less)
The MS5212BZ chip is quite old and I cant find it here where I live so I am looking for any suitable replacement. Ideally it should be temperature-compensated but not necessary.
Does anyone have any recommendations? Links/shops/anything will be much appreciated. It will be used to measure water column pressure, however it does not need to be water-resistant or have any type of insulation as it will be submerged in a mineral oil and sealed with a rubber membrane to keep the water out.
Thank you!
