Hi everyone,
I'm planning on using two size 17 double stacked linear stepper motors for a project I have. I'd like to control them with arduino and a chopper driver(s). However, the specs on the motors are as follows. All specs are per motor:
Bipolar wiring
2.33V
2.6amp / phase (RMS I'm assuming)
power consumption 14W
-> My power supply for the driver/motor (not arduino) will be:
-> 12V to 24V voltage converter (DC... this is going to be going on a vehicle)
-> 200W
-> 8amp
Therefore, what I need is a chopper drive(s) for my motors that will:
-> Accept 24V input to drive the 2.33V motor at 24V
-> I'm assuming it needs to supply 2.6amp continuous then? Or if I run the 2.33V motor at 24V, will the amp draw be less, even when motor is static?
-> Compatible with arduino
-> Possibly some sort of built in voltage/current regulator or something in case my power supply isn't great.. not sure how that works.
Does anybody have any suggestions, please?
Thank you!
