Looking for a LoRa gateway, with a difference. I do not want to get on the IoT. I want the contents of the packets to go to a Mega. Text and GPIO pins. I believe this could be done by modifying the packet forwarder, which is a bit above my skill level.
Has anyone found a library that will handle this requirement?
LoRa radios send data in packets. the sweet thing is, one receiver, countless transmitters. a one channel LoRa gateway can deal with about 30 radios. this is a vast inprovement over 30 transceivers at the receiving end, 30 antenna connections - too much monkey business.
LoRaWAN radios are LoRa radios. The software in the gateway that receives the packets sends them through a packet forwarder to the internet. from there, it goes though the internet to an application server, which processes the packet, determines what to do with the information, then sends back a reply to your system. you are dependent on an external server and an internet connection to handle your needs
I want to use LoRa, as opposed to LoRaWAN. I want my packets to be dealt with by the LoRa gateway in my living room. I want to receive packets, decode them, and either send data to my weather station, or switch closures to my security system, entirely in house. I want the switch closures to set and clear bits on PORTF, to trigger my existing alarm system
I am looking for a gateway optimized for Arduino users. I can't be the first person with these needs.
If you want to setup a LoRaWAN server on a private network, that is possible and there is no compulsion to have an Internet connection. Given the low cost of Gateways these days, its an option that makes sense in a lot of cases.
As for a single channel 'Arduino' LoRa gateway, I dont know of one, but if there is a demand for one, then it ought not to be difficult to find. Or just write your own.
