Hey folks,
I have tried a couple different brands of the inexpensive mini toggles (SPDT or SPST M6x.75 size) and they all have a high failure rate, especially after soldering.
Can someone recommend a brand that holds up under soldering and feels more solid? I dont mind paying more if it is really better quality
All the inexpensive switches have the contacts imbedded in the plastic housing. You need to upgrade you soldering skills to take no more than 1 second to complete the soldering operation and to ensure the plastic won;t get hot, clamp the switch pin with needle nose pliers to act as a heat sink. Use a rubber band to keep the pliers closed.
If you cannot properly solder you can get many of them with screw terminals. If you do not have a temperature controlled iron or lots of experience you are fighting a loosing cause.
C&K and Cherry make good, tough, hi-rel 1/4" mounting switches. Mouser.com is a good vendor. They're not cheap because, well, they're NOT cheap!
Thanks for the tip, I found some NOS C&Ks for $2 apiece which is is not much more then the cheap ones.
What temperature do folks recommend on the soldering iron for doing these? It almost seems like hot and fast would be better.
The temp of the soldering iron depends on the solder. Lead free solder needs a much higher temp than the leaded solder. Then there is the flux needed to clean the metal and keep oxygen away as you heat the metal.
The best/easiest solder is a leaded solder with a mix of 63/37 and has flux in the core of the solder.
IF you have a temperature controlled soldering iron, look up the temperature needed for your solder and set the temp to that value. If your iron is not temperature controlled, learn to solder quickly. With a hot iron. clean the tip quickly on a wadded up paper towel put the tip on the part to be soldered and quickly add the wire solder to the spot where the iron contacts the metal to be soldered and as soon as you see the solder begin to melt, you are done.
hot & fast is how you solder. Hot, but not hot enough cooks the part. Most spec sheets show no more than 5 seconds of solder temp exposure. Practice to get the tempo do
wn before doing it for real.
wipe & re-tin your tip before EVERY connection. Tin the wires separately first, use needle nose pliers to bend a small hook. Slip heat shrink tubing over wire & keep away from end. fit hooked end thru switch solder lug & close the hook. solder quickly, let cool, bring hs tubing in place and shrink with a butane lighter. Just a second or two of heat is usually enough.
final connection should look like this:
