I'm putting this under the sensors category because this is for a sensor probe I plan to build and I'm looking for some ideas.
I'm planning to build a sensor probe out of about a 12 inch long piece of 2 inch (Maybe smaller) PVC tube. Inside the tube, I want to place a DHT22 temperature and humidity probe. Along the outside I want to install a pair of small diameter titanium rods which will be used as a soil moisture sensor. The idea is that I would push the probe down into the soil, placing the DHT22 at the desired depth and use this to measure sub-surface soil temperature, humidity and soil moisture percentage. My only worry is that when the probe is stuck into the ground, first, it's going to get dirt inside it, so something needs to block the end of the tube, but i need to be able to let ambient humidity from the surrounding soil get into the probe housing without letting water simply flow in.
I do realize there are already sub surface probes available inside of a sintered metal housing to do exactly what I'm describing. Unfortunately, it seems that while some of these are priced around $15 USD, for some reason they all want an additional $21 USD for shipping. I'm hoping to come up with a simple solution that doesn't require getting ripped off by dishonest vendors.
Some ideas I have:
Cut a small disk of cinder block with the same outside diameter as the inside diameter of my PVC tube
and maybe a quarter inch thick.
Cover the end of the probe with fabric similar to what is used to make tents, umbrellas and kites. Maybe also coat that in something hydrophobic.
The main purpose here would be to stop the ingress of water to the probe while measurements are being taken. The plan is to put the probe in place, start measuring and begin watering the area with a garden hose or sprinkler. Then, continue to take measurements over the next several hours, perhaps a full 24 hours between tests. I want to try and come up with some good numbers for best time of the day to water, and for how long based on direct measurements being taken over the course of about a week.
All of my leads will be coming out of the top of the probe through a water resistant housing and connected to an Arduino datalogger I have built, which will be at the end of a shielded 25 foot cable. Really the only concern of water ingress is from water in the soil coming up from underneath the probe and damaging the sensor inside.
So far I like the cinder block idea the best, but have not yet attempted to cut any and it sounds like it will be difficult with limited equipment.
Thanks all for any suggestions, I know this is kind of impractical, but I think we can come up with something.
