I'm looking for a recommendation on a small winch that can be controlled via Arduino. I see some which are made for like 1/8 or 1/10 scale model cars that would probably work, but I think they're more of a toy. I need an actual winch. Just a small one, maybe one that can pull 10-20 pounds and be controlled from an Arduino.
Okay, I did some [slightly] more informed research on this. Maybe the servo winch is still a little too complex for what I need, but this is still new to me. Here's what I'm looking for:
I just want to use a winch-like motor (with a string) to raise and lower an object. The object is probably 10-20 pounds. I had envisioned just using a motor with two limit switches--one when the object is at the highest position I desire, and another at the lowest position I desire.
If I just needed to raise the object, I have a pretty good idea how I could do that with a relay, a sufficiently strong motor, and a limit switch. But since I have to be able to reverse the motor, I'm a little confused how to do that. I'm sort of under the assumption I need a reversible motor where I apply a return/ground voltage on one connection, and then a separate connection for voltage to make it turn one way, and another connection to make it turn the opposite way. But I'm really not sure.
The servo winch's I've seen in my limited research on the matter are all over the board in terms of how much weight they can pull, whether they have a six rotation max, or continuous rotation, and different kinds of connections I don't fully understand.
So I ask you, readers, what are my best options for something like this? I had assumed someone would have a good YouTube video on it, but I can't find anything.
Perhaps some other parameters for winch might help. You have only given the winch action for power up and power down. What parameter can you give for NO POWER? Do you want free wheel or do you want the winch to lock in position?
What is the speed required for the object? How much time to raise the object and time to lower the object? Since you are in an Arduino forum, do you require computer control or are you manually controlling the winch?
What power supply are you going to have for the winch? Is the winch to be permanently fixed to something or is it removable?
Have you considered using pulleys or gearing to reduce the torque required by the motor?
You mention using a string for the winch to raise and lower the object. Will your winch require a single layer of string or multiple layers? How will you control the layers of string, if necessary?
Pololu Metal DC Gearmotors has a great assortment of DC motors. If you drill into their website, you will find charts like the following for all of them. You will need to pick one that meets your criteria (rpm, torque, etc.)
The Pololu (and other makers) motors can be fitted with an encoder that will allow your Arduino to count motor revolutions (and hence your winch drum revolutions). Whether that's good enough or safe enough depends on you and your design. Limit switches would be a good backup.
If you want your motor to hold the load after it stops, then you probably want a worm gear drive, which you could create from Servo City parts. Or look for a gear motor with worm gears.
Edit to add the Pololu fine print for the 37D series motoers: "The recommended upper limit for continuously applied loads is 10 kg-cm (150 oz-in), and the recommended upper limit for instantaneous torque is 25 kg-cm (350 oz-in)." So that limits your drum size.
The parameters you need to know before selecting a motor (likely with gearbox) for your project are voltage and current (which are determined from the required motor power in watts) and motor torque.
The torque and power are calculated from the maximum weight to be lifted and the maximum speed with which it is lifted, so defining those quantities is the place to start.
As for power, suppose you want to lift 20 lbs (call it 10 kg) 1 meter in 10 s. The power is 10kgf*(1m)/10s = 1 kgf m/s or about 10 W, so the motor must be rated for more than 10 W.
Torque will depend on the winch drum size. Learn about force and torque here: Pololu - Force and torque
Not a bad idea, but the project and space is very small. This YouTube video shows something along the lines of what I'm thinking. Except, and pertinent to the points made in the previous replies about understanding voltage, torque, etc., I'm thinking I might be able to get a bigger motor that's powered separately (rather than via the arduino as shown in this video) and then activated clockwise and counterclockwise from two relays.
Keep in mind that you should never attempt to power any motor or servo from the Arduino, as that will cause the Arduino to malfunction or even damage it. Ignore the misguided tutorials that suggest otherwise.
I have several of these in various styles. If your still looking for a servo type solution, that one is great for the money. I'm not sure how many turns you need, this one does 5 out of the box, and if you wanted to spend like $15 you could buy their programmer to run it continuous and just run it like a motor. Then all you need is a is a power supply for the servo, an MCU, and if you use really thin rope/string you can just program the start and stop points easily enough (if your not in continuous mode). No need for stop switches and motor drivers and extra hassle
