I'd like to make an Arduino controlled 1 inch solenoid valve for my BBQ smoker. The concern is I want it to open partially under commend, maybe have 0%, 25%, 50%, 75%, and 100% depending on how much air flow it needs.
Any suggestions where i can find one?
Solenoids are usually only open/close, on/off type actuators and you will probably have little luck trying to use it as a linear actuator to modulate flow.
How about, instead of a solenoid valve, use a servo motor or a linear actuator- some models of which behave exactly like servos anyway- to control a baffle?
