Looking for a solution to optimize the program fragment
Hi all.
the program fragment like to set just one mark HIGH and all others LOW, how to optimize it like for-loop?
Thanks
Adam
if (condationA){
  MarkA = 1;
  MarkB = 0;
  MarkC = 0;
  MarkD = 0;
}else if (condationB){
  MarkA = 0;
  MarkB = 1;
  MarkC = 0;
  MarkD = 0;
}else if (condationC){
  MarkA = 0;
  MarkB = 0;
  MarkC = 1;
  MarkD = 0;
}else if (condationD){
  MarkA = 0;
  MarkB = 0;
  MarkC = 0;
  MarkD = 1;
Give examples of what condationA thru condationD might be.
If you’re treating them as separate variables, zero all at the top of the if(), then only set the required 1s in each condition.
Or you could use an array of Marks[] in the same way…
Even a bit array to hold your 0-1 values.
Hello shanren
Consider:
// make names
enum Condition {A, B, C, D};
// make variables
int16_t condition;
// make structures
struct MARK
  Condition condition;
  int16_t value;
MARK mark[] {A, 0, B, 0, C, 0, D, 0};
// make application
  for (auto &mark_ : mark) condition == mark_.condition ? mark_.value = 1 : mark_.value = 0;
    MarkA = MarkB = MarkC = MarkD = 0;
    switch (condition) {
    case CondA:
        MarkA = 1;
    case CondB:
        MarkB = 1;
    case CondC:
        MarkC = 1;
    case CondD:
        MarkD = 1;
Do you need 4 separate variables?
Could you just use 1 bit to represent each condition?
uit8_t mark;
mark =0;
if( conditionA )  mark |= 0x01;
if( conditionB )  mark |= 0x02;
if( conditionC )  mark |= 0x04;
if( conditionD )  mark |= 0x08;
or
struct {
   unsigned int A: 1;
   unsigned int B: 1;
   unsigned int C: 1;
   unsigned int D: 1;
} mark;
if( conditionA )  mark.A = 1;
if( conditionB )  mark.B = 1;
if( conditionC )  mark.C = 1;
if( conditionD )  mark.D = 1;
Thanks.
They are buttons or touch screen soft buttons.
Thanks.
I did this way, but seems something not right in my code or ? I got expected result till I used the way in #1 post.
Sorry, my code don't have " zero all at the top of the if(), " and just zero all at the header config, maybe this is the reason?
Tested the way here can't control individual mark's 0 or 1.
Thanks.
I'll check it.
Have a nice day.
Thanks.
It works!
Thanks.
They are manually controlled buttons.
MarkA=(condationA?1:0);
MarkB=(condationB?1:0);
MarkC=(condationC?1:0);
MarkD=(condationD?1:0);
You could treat all the Mark variables as bool, and just have:
MarkA = condationA;
MarkB = condationB;
MarkC = condationC;
MarkD = condationD;
So MarkA will be true or false corresponding to whether the condationA evaluates as true or false, etc ...
Thanks.
I'll test it.
... or force it to be boolean:
MarkA = (bool)condationA;
MarkB = (bool)condationB;
MarkC = (bool)condationC;
MarkD = (bool)condationD;
a program fragment can't show enough context.
for example instead of MarkA, MarkB, MarkC, MarkD ... consider one Mark[4]
or why 4 variables at all.
in binary that information would fit in a single byte variable also.
That would be too simple. Just think of it: C++ uses byte for bool. Why would you want to make it smaller?
On an AVR UNO, RAM is quite precious ...
conditionA is likely a bool already
Indeed it has to be - as it was the condition of an if in the OP:
