I need your help to find the ideal component.
I want to power a wireless circuit on battery, a lipo one.
The lipo voltage should go from 4,2V when fully charged, to 3V when dead.
All the components of the circuit will behave nicely at 3V and more, but some will be fried over 3,6V. So I need to keep voltage between 3 and 3.6V.
-> I first thought using a 3.6 zener diode to clamp voltage, but it seems quite inefficient for a wireless circuit.
-> I could use a LDO regulator at 3V. But why wasting energy to get voltage down to 3V whereas when between 3 and 3.6V raw voltage would be ok for direct powering…
-> I have been reading something about some LDO regulators that would let raw voltage flow through them when under the regulated voltage.
This would be perfect, while over 3.6V, the regulator does its job and gets it down to 3.6V. When voltage drop under 3.6V, the circuit is powered by raw voltage passing through the regulator.
But I just can’t find this type of LDO regulators ? How is it named ?
All the regulators I see just shut the power down when under the minimum voltage.
Thanks,
Julien
