Arduino with Ethernet Shield
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
int led = 4;
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 117 }; // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(8085); //server port
String readString;
// Relay state and pin
String relay1State = "Off";
const int relay = 40;
// Client variables
char linebuf[80];
int charcount=0;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(relay, OUTPUT);
digitalWrite(relay, HIGH);
microservo.attach(24);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
//void loop() {
// Create a client connection
//EthernetClient client = server.available();
void dashboardPage(EthernetClient &client) {
client.println("<!DOCTYPE HTML><html><head>");
client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\"></head><body>");
client.println("<h3>Arduino Web Server - <a href=\"/\">Refresh</a></h3>");
// Generates buttons to control the relay
client.println("<h4>Relay 1 - State: " + relay1State + "</h4>");
// If relay is off, it shows the button to turn the output on
if(relay1State == "Off"){
client.println("<a href=\"/relay1on\"><button>ON</button></a>");
// If relay is on, it shows the button to turn the output off
else if(relay1State == "On"){
client.println("<a href=\"/relay1off\"><button>OFF</button></a>");
client.println("<TITLE>Random Nerd Tutorials Project</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Random Nerd Tutorials Project</H1>");
client.println("<hr />");
client.println("<br />");
client.println("<H2>Arduino with Ethernet Shield</H2>");
//client.println("<br />");
//client.println("<a href=\"/?button1on\"\">Turn On LED</a>");
//client.println("<a href=\"/?button1off\"\">Turn Off LED</a><br />");
client.println("<a href=\"/?button2on\"\">Rotate Left</a>");
client.println("<a href=\"/?button2off\"\">Rotate Right</a><br />");
//client.println("<p>Created by Rui Santos. Visit https://randomnerdtutorials.com for more projects!</p>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?button1on") >0){
digitalWrite(led, HIGH);
if (readString.indexOf("?button1off") >0){
digitalWrite(led, LOW);
if (readString.indexOf("?button2on") >0){
for(pos = 0; pos < 120; pos += 3) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
microservo.write(pos); // tell servo to go to position in variable 'pos'
// delay(15); // waits 15ms for the servo to reach the position
if (readString.indexOf("?button2off") >0){
for(pos = 90; pos>=1; pos-=3) // goes from 180 degrees to 0 degrees
//delay(15); // waits 15ms for the servo to reach the position
//clearing string for next read
readString="";
// listen for incoming clients
if (client) {
Serial.println("new client");
memset(linebuf,0,sizeof(linebuf));
charcount=0;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
linebuf[charcount]=c;
if (charcount<sizeof(linebuf)-1) charcount++;
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
dashboardPage(client);
if (c == '\n') {
if (strstr(linebuf,"GET /relay1off") > 0){
else if (strstr(linebuf,"GET /relay1on") > 0){
digitalWrite(relay, LOW);
relay1State = "On";
// you're starting a new line
charcount=0;
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
for(pos = 0; pos < 180; pos += 3) // goes from 0 degrees to 180 degrees
for(pos = 180; pos>=1; pos-=3) // goes from 180 degrees to 0 degrees
readString="";
Serial.println("client disonnected");
@mehdibh, your topic has been moved to a more suitable location on the forum.
Please edit your post, select all code and click the </> button; Next save the post. That way we don't have to look at byte mac[] but it will be properly rendered as byte mac[].
Please take some time to read How to get the best out of this forum.
I take note
thanks for advising
