Looking for a very small display
Hey guys!
I am facing a project where the 0.96" display that I usually use is too big to fit. Unfortunately, I can't really find anything similar that is smaller. Can someone point me in the right direction for something small?
The closest I have found is this one: http://www.buydisplay.com/default/low-power-smallest-blue-i2c-0-49-inch-64x32-oled-module-display-ssd1306
I am a little confused about all the pins, though. Can it be used with Arduino?
Thx, Rasmus
The "SSD1306" part is the interface; googling on that will point you to the libraries you need.
Those ribbon connectors require a special receptacle to connect them to a board; you really want to avoid that. Fortunately you can find these displays pre-mounted on PCBs that will be a lot easier to use. Adafruit.com will have them and the tutorials you need to use them.
I created at 0.66" oled display that may be of use. i2c or SPI but it's in an odd shape custom made for the bean: https://www.youtube.com/watch?v=9dsmerMvnrY
Mike
Thanks for both your suggestions. I really appreciate it.
Chagrin:
The “SSD1306” part is the interface; googling on that will point you to the libraries you need.
The smallest one I can find on adafruit is this one:
Unfortunately, that one is still too big.
I was thinking of using a FPC breakout board for the one I originally mentioned, but I still cant figure out what to do with the 14 connections. Normally when interfacing with a display, I only use 4-5ish…
An easy to use model like the adafruit one but in a smaller size would definitely be the best way to go. Hoping to find such one :-)
What about this:
http://www.seeedstudio.com/depot/05-inch-OLED-display-Arduino-shield-p-2194.html
Oliver
http://technabob.com/blog/2014/03/25/microview-arduino-with-oled-screen/
http://www.4dsystems.com.au/product/uOLED_96_G2_AR/
