Looking for advice for which library I might be able to use
I am looking for a library I can use on the MKR series (samd cortex m0) that enables me to output a varying frequency pulse through a digital output. I want to be able to change the frequency of the pulse to emulate a simple encoder. I imagine the range 0-100Hz would be fine.
I've tried the standard tone.h libraries and similar but they won't compile for the board unsurprisingly.
I'm using ros2arduino and I'm receiving the desired frequency in a message from a connected computer. I am also publishing ros messages back at a frequency of 10hz so I need to make sure that I'm not delaying the main loop inappropriately.
Can anyone suggest a way I can do this?
Thanks in advance for any help given, if more information is needed I can add it. It might be a bit waffly but I'm relatively new to all this so apologies if that's the case.
Rob
Hi Rob,
Unfortunately, I don’t have a library, but here’s some code that sets the PWM frequency from 1 to 100Hz on pin D7 of the MKR WiFi 1010:
// Output 1 to 100Hz PWM on digital pin D7 using the MKR WiFi 1010
  // Use GCLK0 at 48MHz as a clock source for  TCC0 and TCC1
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN |         // Enable GCLK0 as a clock source
                      GCLK_CLKCTRL_GEN_GCLK0 |     // Select GCLK0 at 48MHz
                      GCLK_CLKCTRL_ID_TCC0_TCC1;   // Route GCLK0 to TCC0 and TCC1
  while (GCLK->STATUS.bit.SYNCBUSY);               // Wait for synchronization
  // Enable the port multiplexer for pins D7
  PORT->Group[g_APinDescription[7].ulPort].PINCFG[g_APinDescription[7].ulPin].bit.PMUXEN = 1;
  // D7 is on ODD port pin PA21 and TCC1/WO[7] = channel 3 is on peripheral F
  // Note that TCC0 timer channels 0 to 3 are repeated on 4 to 7, therefore output WO[7] is on channel 3
  PORT->Group[g_APinDescription[7].ulPort].PMUX[g_APinDescription[7].ulPin >> 1].reg |= PORT_PMUX_PMUXO_F;
  // Normal (single slope) PWM operation: timer countinuously counts up to PER register value and then is reset to 0
  TCC0->WAVE.reg = TCC_WAVE_WAVEGEN_NPWM;          // Setup single slope PWM on TCC0
  while (TCC0->SYNCBUSY.bit.WAVE);                 // Wait for synchronization
  TCC0->CC[3].reg = 30000000;                      // TCC0 CC3 - 50% duty cycle on D7
  while (TCC0->SYNCBUSY.bit.CC3);                  // Wait for synchronization
  TCC0->PER.reg = 59999999;                        // TCC0 PER - set frequency to 1Hz: 48MHz / (8 * 1) - 1 = 5999999
  while (TCC0->SYNCBUSY.bit.PER);                  // Wait for synchronization
  TCC0->CTRLA.reg = TC_CTRLA_PRESCALER_DIV8 |      // Set prescaler to 8, 48MHz/8 = 6MHz
                    TC_CTRLA_PRESCSYNC_PRESC;      // Set the reset/reload to trigger on prescaler clock
  TCC0->CTRLA.bit.ENABLE = 1;                      // Enable the TCC0 counter
  while (TCC0->SYNCBUSY.bit.ENABLE);               // Wait for synchronization
void loop()                                        // PWM frequency sweep low to high
  for (uint8_t frequency = 1; frequency <= 100; frequency++)    // Iterate through PWM frequencies 1Hz to 100Hz
    // Calculate the timer period value : Tclk / (Tprescaler * frequency) - 1
    uint32_t timerPeriod = 48000000 / (8 * frequency) - 1;
    uint32_t dutycycle = (timerPeriod + 1) / 2;     // Set the duty-cycle to 50%
    // Using buffered counter compare registers (CCBx)
    TCC0->CTRLBSET.bit.LUPD;                        // Set the Lock Update bit to stop updates from occuring
    while (TCC0->SYNCBUSY.bit.CTRLB);               // Wait for synchronization
    TCC0->CCB[3].reg = dutycycle;                   // TCC0 CCB3 - 50% duty cycle on D7
    while (TCC0->SYNCBUSY.bit.CCB3);                // Wait for synchronization
    TCC0->PERB.reg = timerPeriod;                   // TCC0 PERB - set frequency
    while (TCC0->SYNCBUSY.bit.PERB);                // Wait for synchronization
    TCC0->CTRLBCLR.bit.LUPD;                        // Clear the Lock Update bit to resume updates
    delay(1000);                                    // Wait for a minimum of 1 second
Thanks MartinL,
I've coded a solution just using millis() which works as I wanted. Your solution is very neat though, definitely going in the vault of useful code!
Rob
