looking for arduino programmer who likes music related projects
this is my first project,
and i have a little budget
what is your price and time frame please?
thanks
if you want to make this function with another code or board just tell me.
this code is a step sequencer that plays notes based on frequency,
I would like it to send numbers and letters to a computer by a usb cable.
i would like to use this on my arduino micro
and use a 24 step rotary encoder instead of a simple potentiometer or another similar solution
as a number/letter selector.
I would like to change the below code so that instead of inputing a frequency (#define AnalogInFrequency 1) for the choices of musical notes,
It chooses a letter or a number in this list, it scrolls through part of the ascii list included with project.
and sends those number/letters sequenced through a usb cable on a arduino micro to a computer
numbers and letters to be used:
48 060 30 00110000 0 0 Zero
49 061 31 00110001 1 1 One
50 062 32 00110010 2 2 Two
51 063 33 00110011 3 3 Three
52 064 34 00110100 4 4 Four
53 065 35 00110101 5 5 Five
54 066 36 00110110 6 6 Six
55 067 37 00110111 7 7 Sevena
56 070 38 00111000 8 8 Eight
57 071 39 00111001 9 9 Nine
97 141 61 01100001 a a Lowercase a
98 142 62 01100010 b b Lowercase b
99 143 63 01100011 c c Lowercase c
100 144 64 01100100 d d Lowercase d
101 145 65 01100101 e e Lowercase e
102 146 66 01100110 f f Lowercase f
103 147 67 01100111 g g Lowercase g
104 150 68 01101000 h h Lowercase h
105 151 69 01101001 i i Lowercase i
106 152 6A 01101010 j j Lowercase j
107 153 6B 01101011 k k Lowercase k
108 154 6C 01101100 l l Lowercase l
109 155 6D 01101101 m m Lowercase m
110 156 6E 01101110 n n Lowercase n
111 157 6F 01101111 o o Lowercase o
112 160 70 01110000 p p Lowercase p
113 161 71 01110001 q q Lowercase q
114 162 72 01110010 r r Lowercase r
115 163 73 01110011 s s Lowercase s
116 164 74 01110100 t t Lowercase t
117 165 75 01110101 u u Lowercase u
118 166 76 01110110 v v Lowercase v
119 167 77 01110111 w w Lowercase w
120 170 78 01111000 x x Lowercase x
121 171 79 01111001 y y Lowercase y
122 172 7A 01111010 z z Lowercase z
code to modify
Arduino Punk Console
A simple programmable 8 step tone sequencer
by dano/beavisaudio.com
Revs
15 Sept  djh  initial version
// Map all the input and output pins
#define AnalogInTempo 2
#define AnalogInDuration 0
#define DigitalOutSignal 11
#define DigitalInSwitch0 2
#define DigitalInSwitch1 3
#define DigitalInSwitch2 4
#define DigitalInSwitch3 5
#define DigitalInSwitch4 6
#define DigitalInSwitch5 7
#define DigitalInSwitch6 8
#define DigitalInSwitch7 9
#define DigitalInStartStop 10
#define DigitalOutLED 12
// Set up the array for each step
int steps[] = {100,120,140,160,180,200,220,240};
// misc housekeeping
int duration = 50;
int pitchval = 1;
int fPlayMode = true;
int lastPushedStep = -1;
// Initialize the tempo
int tempo = 100;
  // setup pin modes (Digital pins are input by default, but
  // I like to set 'em explicitly just so the code is clear.
  pinMode (DigitalInSwitch0, INPUT);
  pinMode (DigitalInSwitch1, INPUT);
  pinMode (DigitalInSwitch2, INPUT);
  pinMode (DigitalInSwitch3, INPUT);
  pinMode (DigitalInSwitch4, INPUT);
  pinMode (DigitalInSwitch5, INPUT);
  pinMode (DigitalInSwitch6, INPUT);
  pinMode (DigitalInSwitch7, INPUT);
  pinMode (DigitalInStartStop, INPUT);
  pinMode (DigitalOutSignal, OUTPUT);
  pinMode (DigitalOutLED, OUTPUT);
  // Main sequence loop
  for (int i=0; i<8; i++)
    // Are we playing or stopping?
    fPlayMode = digitalRead (DigitalInStartStop);
    digitalWrite (DigitalOutLED, HIGH);
    // Check the Hardware
     readSwitches();
     readPots();
    // update the display
    updateDisplay();
    // Make the noise
    if (fPlayMode)
      freqout (steps, duration);
    digitalWrite (DigitalOutLED, LOW);
    // Pause between steps
    delay (tempo);
void updateDisplay()
  Serial.print (254, BYTE);
  Serial.print (192, BYTE);
  Serial.print ("T:");
  Serial.print (tempo);
  Serial.print (" d:");
  Serial.print (duration);
if (lastPushedStep != -1)
    Serial.print ("*");
    Serial.print (lastPushedStep);
// Read the current values of the pots, called from the loop.
void readPots ()
    tempo = (analogRead (AnalogInTempo) * 1.9);
    duration = (analogRead (AnalogInDuration));
// Read the current values of the switches and
// if pressed, replace the switch's slot frequency
// by reading the frequency pot.
void readSwitches()
  // reset last pushed button number
  // check switch 0, if pressed, get the current freq into step 0, etc. etc.
  if (digitalRead (DigitalInSwitch0) == HIGH)
    steps[0] = analogRead(AnalogInFrequency);
    lastPushedStep = 1;
  else if (digitalRead (DigitalInSwitch1) == HIGH)
    steps[1] = analogRead(AnalogInFrequency);
    lastPushedStep = 2;
  else if (digitalRead (DigitalInSwitch2) == HIGH)
    steps[2] = analogRead(AnalogInFrequency);
    lastPushedStep = 3;
  else if (digitalRead (DigitalInSwitch3) == HIGH)
    steps[3] = analogRead(AnalogInFrequency);
    lastPushedStep = 4;
  else if (digitalRead (DigitalInSwitch4) == HIGH)
    steps[4] = analogRead(AnalogInFrequency);
    lastPushedStep = 5;
  else if (digitalRead (DigitalInSwitch5) == HIGH)
    steps[5] = analogRead(AnalogInFrequency);
    lastPushedStep = 6;
  else if (digitalRead (DigitalInSwitch6) == HIGH)
    steps[6] = analogRead(AnalogInFrequency);
    lastPushedStep = 7;
  else if (digitalRead (DigitalInSwitch7) == HIGH)
    steps[7] = analogRead(AnalogInFrequency);
    lastPushedStep = 8;
//freqout code by Paul Badger
// freq - frequency value
// t - time duration of tone
void freqout(int freq, int t)
  int hperiod;     //calculate 1/2 period in us
  long cycles, i;
  // subtract 7 us to make up for digitalWrite overhead - determined empirically
  hperiod = (500000 / ((freq - 7) * pitchval));
  // calculate cycles
  cycles = ((long)freq * (long)t) / 1000;    // calculate cycles
  for (i=0; i<= cycles; i++)
  {              // play note for t ms
    digitalWrite(DigitalOutSignal, HIGH);
    delayMicroseconds(hperiod);
    digitalWrite(DigitalOutSignal, LOW);
    delayMicroseconds(hperiod - 1);     // - 1 to make up for fractional microsecond in digitaWrite overhead
So you want a keyboard?
i want a step sequencer keyboard,
can you help
i am currently trying to set ranges for the note potentiometer,
and replace the note information by keyboard keys:
1-28 (hz?): it sends a 1
28-56 it sends a 2
996-1024 it sends a z
can you tell me where to add this to the code,
it doesnt matte if the original code continues as usual.
any help wanted thx
Sorry, I don’t understand what you are talking about.
