Ive been working on a little project trying to add automatic headlights to an older car. I have a light sensor from a newer vehicle sending a signal to arduino to control a relay turning the lights on.
I have everything working however, when the light is at the threshold value it is spamming the relay and making a buzzing noise. I was wondering what I could add to the code to try and make it work better. Thanks!
pinMode(10, OUTPUT); // sets the digital pin 10 as output relay ground signal
int analogPin = analogRead(A1); // read the input pin
if(analogPin <=390){
digitalWrite(10,LOW); // sets the digital pin 10 on
else{
(digitalWrite(10,HIGH));
Read about "hysteresis" for a full explanation. It is used in thermostats, light sensors, motor RPM...
For your particular issue, rather than having ON/OFF border on a single value (for example, 50), use a "deadband" that lets the current state remain active even while out-of-bounds. Assuming your current code ON/OFF threshold is "50"... try...
if (light_value > 55) // more light present, turn lights off
lightOFF();
// if light_value is between 45 and 55... nothing changes the state
if (light_value < 45) // less light present, turn lights on
lightON();
This shows a deadband of 45 to 55 where the light will stay in the current state until well past the opposite threshold. For example if the light is OFF due to light_value being over 55 and light_value then changed to 50, there is no discrete condition for 50, so the light is neither turned off nor turned on... until it passes the deadband.
