Looking for circuit design feedback (UNO, Two Servos, Proximity Sensor and LEDs)
Yes, ~600mA max is typical for 12 LEDs.
A limit can be set in the sketch if needed.
Wise to add a small ~330ohm resistor between Arduino pin and LED data input.
Upload a final diagram.
Leo..
Wawa:
Leo..
I wasn't able to get back to this yesterday, but am today.
Working on the final diagram — question though — if I power the Ultrasonic sensor and the LED from the arduino 5V Pin knowing I'll have enough current... do I still need to add capacitors for those two peripherals?
creatify:
...if I power the Ultrasonic sensor and the LED from the arduino 5V Pin knowing I'll have enough current... do I still need to add capacitors for those two peripherals?
Depends on the distance between Arduino and devices.
If <30cm, then don't bother. If longer, add.
Remove ground wire from supply cable to Arduino board.
The DC connector already does that.
Connect HC-SR04 and LED grounds to Arduino board ground, not to the supply cable.
Leo..
Wawa:
That is very helpful advice, thank you, Wawa.
Remove ground wire from supply cable to Arduino board. The DC connector already does that.
Got it — I'll only need to use that ground wire if I'm powering the peripherals by the external power, and powering the arduino with USB.
Got it!
I'm hoping I can resurrect this thread now that I've made more progress. The circuit works as my last diagram indicates.
However, I'm getting a ton of twitching on the servos. Some thoughts:
  • The voltage in my 'bucks' is set to 5V, but does fluctuate some (+- 0.07V). This is noticeable when checking the voltage PAST my 470uF capacitors, directly where the servo connects.
  • Per research, I've played with adding a delay in my loop and around the write calls, a delay of 100 in my loop does appear to lessen the twitching. Granted, I have kept / tested 20ms+ delays around the servo write calls. I'd like to avoid the delays as I'm using up a finite state machine. Using a state machine to delay writes did not seem to help it. Am I correct in thinking this must be more due to the buck / 7.5V 3.2A adapter. Oh and, it is a regulated switching adapter — I can't really find a true, regulated only adapater anywhere yet.
  • Researching, I see mention of using a resistor, but I'm not understanding where or how that would help.
    Also, I'm not sure I should be looking at the data line or the 5+/Grnd — I haven't yet grasped how these are 'related'
It works, the circuit really works! Thank you, Wawa, for all the direction.
I did have some issues with my Adafruit NeoPixel library and the Servo library causing a bunch of servo-twitching, but resolved/mitigated that by using another servo library.
Good to hear you have it working smoothly.
Can you post your final code and let us know what library, link to where you got it, you finally used.
This will finalize this thread perfectly.
Thanks.. Tom.. :slight_smile:
