I am looking for data on this device:
Thank You
donvukovic:
I am looking for data on this device:Thank You
If you bought it on Ebay, ask the seller.
Paul
Or better, yet! Just look at the ad on Ebay. All the specs are there, Shees!!!
I bought 10 of these 3-4 years ago. Found them in a box in the garage.
If you can't answer, why waste your time to be a dick ?
donvukovic:
I bought 10 of these 3-4 years ago. Found them in a box in the garage.If you can't answer, why waste your time to be a dick ?
I guess you are right. If you are too lazy to Google search yourself, I am wasting my time.
Looks like a 2.4GHz transceiver board. Are the IO pins at the bottom marked at all?
Perhaps an older nrf24L01 module.
CrossRoads:
The Chinese seller still has them on Ebay, along with ALL the specs needed.
Paul
It looks like those things that play a tune in a birthday card.
CrossRoads:
Yes, I bought these but no longer can find any data.
There are no markings except for the pic supplied.
This is your board, different layout.
Paul
Paul_KD7HB:
This is your board, different layout.Paul
so, it's NOT the same footprint.
How would you count the pins ?
I did find that one as well.
My ohm meter shows ground is not in the same place.
Now what ?
donvukovic:
so, it's NOT the same footprint.How would you count the pins ?
Now what ?
But all the same resistors and capacitors and number of connections and the black blob! Looks like a couple on the side of the board. You just have to identify what is what.
Paul
edit: And the antenna layout is identical, so frequencies are the same.
