Looking for easy VR3 for relay shield code help
Hello : I have a ONU with a easy VR3 shield and a DFrobot four relay shield .
I have VR 3 working but having coding problem for the relays .I have my groups working when i test it on the serial monitor. but cant get code right to output to D2,7,8,10 .
Post your best effort at the code
Please follow the advice given in the link below when posting code . Use code tags when posting code here to make it easier to read and copy for examination
Hello: not getting any error code , not getting say command in group 1 on serial monitor. just trying to turn on and off relay 1 now. Im missing some thing to new to c++ to find it.
thanks Ed
int relay_1 = 2;
int relay_2 = 7;
int relay_3 = 8;
int relay_4 = 10;
#include "Arduino.h"
#if !defined(SERIAL_PORT_MONITOR)
#error "Arduino version not supported. Please update your IDE to the latest version."
#endif
#if defined(__SAMD21G18A__)
// Shield Jumper on HW (for Zero, use Programming Port)
#define port SERIAL_PORT_HARDWARE
#define pcSerial SERIAL_PORT_MONITOR
#elif defined(SERIAL_PORT_USBVIRTUAL)
// Shield Jumper on HW (for Leonardo and Due, use Native Port)
#define pcSerial SERIAL_PORT_USBVIRTUAL
#else
// Shield Jumper on SW (using pins 12/13 or 8/9 as RX/TX)
#include "SoftwareSerial.h"
SoftwareSerial port(12, 13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_COMPUTER = 0,
enum Group1
  G1_LIGHTS_ON = 0,
  G1_TURN_LIGHTS_OFF = 1,
//Grammars and Words
enum Wordsets
  SET_1  = -1,
  SET_2  = -2,
  SET_3  = -3,
enum Wordset1
  S1_ACTION = 0,
  S1_MOVE = 1,
  S1_TURN = 2,
  S1_RUN = 3,
  S1_LOOK = 4,
  S1_ATTACK = 5,
  S1_STOP = 6,
  S1_HELLO = 7,
enum Wordset2
  S2_LEFT = 0,
  S2_RIGHT = 1,
  S2_UP = 2,
  S2_DOWN = 3,
  S2_FORWARD = 4,
  S2_BACKWARD = 5,
enum Wordset3
  S3_ZERO = 0,
  S3_ONE = 1,
  S3_TWO = 2,
  S3_THREE = 3,
  S3_FOUR = 4,
  S3_FIVE = 5,
  S3_SIX = 6,
  S3_SEVEN = 7,
  S3_EIGHT = 8,
  S3_NINE = 9,
  S3_TEN = 10,
// use negative group for wordsets
int8_t group, idx;
  // setup PC serial port
  pcSerial.begin(9600);
  pinMode(relay_1, OUTPUT);
  pinMode(relay_2, OUTPUT);
  pinMode(relay_3, OUTPUT);
  pinMode(relay_4, OUTPUT);
bridge:
  // bridge mode?
  int mode = easyvr.bridgeRequested(pcSerial);
  switch (mode)
    case EasyVR::BRIDGE_NONE:
      // setup EasyVR serial port
      port.begin(9600);
      // run normally
      pcSerial.println(F("Bridge not requested, run normally"));
      pcSerial.println(F("---"));
    case EasyVR::BRIDGE_NORMAL:
      // setup EasyVR serial port (low speed)
      port.begin(9600);
      // soft-connect the two serial ports (PC and EasyVR)
      easyvr.bridgeLoop(pcSerial);
      // resume normally if aborted
      pcSerial.println(F("Bridge connection aborted"));
    case EasyVR::BRIDGE_BOOT:
      // setup EasyVR serial port (high speed)
      port.begin(115200);
      pcSerial.end();
      pcSerial.begin(115200);
  // initialize EasyVR
  while (!easyvr.detect())
    pcSerial.println(F("EasyVR not detected!"));
    for (int i = 0; i < 10; ++i)
      if (pcSerial.read() == '?')
        goto bridge;
      delay(100);
  pcSerial.print(F("EasyVR detected, version "));
  pcSerial.print(easyvr.getID());
  if (easyvr.getID() < EasyVR::EASYVR3)
    easyvr.setPinOutput(EasyVR::IO1, LOW); // Shield 2.0 LED off
  if (easyvr.getID() < EasyVR::EASYVR)
    pcSerial.print(F(" = VRbot module"));
  else if (easyvr.getID() < EasyVR::EASYVR2)
    pcSerial.print(F(" = EasyVR module"));
  else if (easyvr.getID() < EasyVR::EASYVR3)
    pcSerial.print(F(" = EasyVR 2 module"));
    pcSerial.print(F(" = EasyVR 3 module"));
  pcSerial.print(F(", FW Rev."));
  pcSerial.println(easyvr.getID() & 7);
  easyvr.setDelay(0); // speed-up replies
  easyvr.setTimeout(5);
  easyvr.setLanguage(0); //<-- same language set on EasyVR Commander when code was generated
  group = EasyVR::TRIGGER; //<-- start group (customize)
    easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  if (group < 0) // SI wordset/grammar
    pcSerial.print("Say a word in Wordset ");
    pcSerial.println(-group);
    easyvr.recognizeWord(-group);
  else // SD group
    pcSerial.print("Say a command in Group");
    pcSerial.println(group);
    easyvr.recognizeCommand(group);
  do
    // allows Commander to request bridge on Zero (may interfere with user protocol)
      setup();
      return;
    // <<-- can do some processing here, while the module is busy
  while (!easyvr.hasFinished());
    easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx == 0 && group == EasyVR::TRIGGER)
    // beep
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // print debug message
    pcSerial.println("Word: ROBOT");
    // write your action code here
    // group = GROUP_X\SET_X; <-- jump to another group or wordset
    return;
  else if (idx >= 0)
    // beep
    uint8_t flags = 0, num = 0;
    char name[32];
    pcSerial.print("Word: ");
    pcSerial.print(idx);
    if (easyvr.dumpGrammar(-group, flags, num))
      for (uint8_t pos = 0; pos < num; ++pos)
        if (!easyvr.getNextWordLabel(name))
        if (pos != idx)
          continue;
        pcSerial.print(F(" = "));
        pcSerial.println(name);
    // perform some action
    action();
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // beep
    uint8_t train = 0;
    char name[32];
    pcSerial.print("Command: ");
    if (easyvr.dumpCommand(group, idx, name, train))
      pcSerial.print(" = ");
      pcSerial.println();
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      pcSerial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      pcSerial.print("Error ");
      pcSerial.println(err, HEX);
void action()
  switch (group)
    case GROUP_0:
      switch (idx)
        case G0_COMPUTER:
          // group = GROUP_X\SET_X; <-- or jump to another group or wordset for composite commands
    case GROUP_1:
      switch (idx)
        case G1_LIGHTS_ON:
          //  digitalWrite(relay_1, HIGH);
        case G1_TURN_LIGHTS_OFF:
          // digitalWrite(relay_1, LOW);
    case SET_1:
      switch (idx)
        case S1_ACTION:
        case S1_MOVE:
        case S1_TURN:
        case S1_RUN:
        case S1_LOOK:
        case S1_ATTACK:
        case S1_STOP:
        case S1_HELLO:
    case SET_2:
      switch (idx)
        case S2_LEFT:
        case S2_RIGHT:
        case S2_UP:
        case S2_DOWN:
        case S2_FORWARD:
        case S2_BACKWARD:
    case SET_3:
      switch (idx)
        case S3_ZERO:
        case S3_ONE:
        case S3_TWO:
        case S3_THREE:
        case S3_FOUR:
        case S3_FIVE:
        case S3_SIX:
        case S3_SEVEN:
        case S3_EIGHT:
        case S3_NINE:
        case S3_TEN:
