Looking for example sketch for SD operation for DFRobot W5500 Ethernet
I'm looking for sketch examples how to use SD card in DFRobot DFR0342 ( link ).
I tried to use example (e.g CardInfo) from Arduino IDE but it does not work. I've got "Initializing SD card...initialization failed."
I thing that maybe examples use improper port for SPI - example use (at least in comment is such info) MOSI - pin 11 , MISO - pin 12 ,vCLK - pin 13 but there is no information how to change it or maybe it change automaticly when proper Arduino board is selected ?
Regards Michał
That's because the SPI bus is tied to specific pins. You can NOT change the pins without a soldering iron.
Which pin are you specifying for the chip/slave select pin? On most Ethernet shields, the SD card's slave select pin is pin 4.
