Looking for external microphone references
For a project using the arduino nicla voice i would need to use external microphones for an appropriate placement of those.
I saw that the board has an external microphone connector of type :
An external PDM microphone can be connected to the board via an onboard Zero Insertion Force (ZIF) connector. The manufacturer part number of the onboard ZIF connector is FH33J-4S-0.5SH(99); a 4-pin 0.5 mm pitch FFC cable is compatible with this connector.
But I can't find any microphones for microcontrollers that have these type of ports, do you have references for this type of microphones or a place where I can find them ?
I also saw that the board has 2 analog pins (adc1/p0_02 and adc2/p0_30). Would I be able to connect analog microphones using those pins and retrieve their data ? If its possible, which microphone can I buy, and how would you proceed to connect them to the board? Does it require soldering or is there another way to use them? (would these microphones be usable with the nicla voice : first, second)
Thanks in advance
Dear mbm974 did you found a solution? It would be something that interests me too.
thanks in advance.
bst,
pierluigi
Hello Pierbert,
Didn't find anything unfortunately, ended up using another board for this project
Good luck to you
Hello, thank you all the same,
bst
pierluigi
