Looking for good LCD Keypad combo.
I’ve read some bad reviews on the ones I’ve found. Would I be better off getting an LCD and a seprate keypad? This is to control the dim and timer on an LED light.
If you read http://arduino.cc/forum/index.php/topic,96747.0.html you can buy any of those (and even cheaper clones on eBay http://arduino.cc/forum/index.php/topic,120550.0.html) if you are prepared to do some soldering.
Backlight control will then work. Not sure what you mean by
timer
For LCD and separate keypad, here is what I designed and sell:
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/serial-lcd-back-pack---phi-panel/
No bad reviews so far :)
The entire LCD + keypad is controlled by an ATMEGA328 controller. Arduino talks to the controller with soft or hardware serial port. Key presses are read with Serial.read. LCD is updated with Serial.print
