Looking for guide to set up open source project to run on multiple microcontller
I've created a device for measuring system latency, first using an arduino, then an itsy-bitsy, and now a custom PCB. I designed the Windows software/driver/whatever it's called that reads the USBs input, but an EE friend has helped me port it from each different config to the next.
Since this is the case, I'm not sure what my best options are for making the program portable.
One of the first lines in the program is a major culprit:
// LiquidCrystal(rs, rw, enable, d4, d5, d6, d7) //Arduino pinout?
// LiquidCrystal lcd(4, 6, 8, 10, 11, 12, 13);   //adafruit itsybitsy prototype version
   LiquidCrystal lcd(8, 6, 4, 0, 1, 9, 5);      //syslat custom pcb version
Should I be using something like:
#IFDEF __ARDUINO__
#IFDEF __ITSYBITSY__
#IFDEF __CUSTOMPCB__
Or something else?
Here's the full source (225 lines) if needed: GitHub - Skewjo/SysLat_Firmware: Arduino firmware for SysLat project
if all your microcontrollers are loading an arduino sketch then you need to look at what #define is indeed specific for a given target platform and have that into your library.
There are two standardized macros provided by the build system:
These can be used to switch architecture-specific code, as described here:
https://arduino.github.io/arduino-cli/latest/library-specification/#working-with-multiple-architectures
That's in the Arduino library documentation, but it applies just as well to sketches.
The individual toolchains may also provide their own macros, for example:
https://www.nongnu.org/avr-libc/user-manual/using_tools.html
