Hi! I am currently working on an Arduino Simblee Lilypad and a pulse sensor. With a mobile app SimbleeForMobile, I can show the data on my phone, because the Simblee Lilypad supports Bluetooth.
The trouble is the data showed on my phone is not transferred and I don't know how to transfer that! The normal heartbeat should be some number like 90, 80, etc.. But the raw data is like 700+, 600+, etc..
Does anyone have an idea about this? Thanks!
Here is the code:
The sketch demonstrates how to do accept a Bluetooth Low Energy 4
Advertisement connection with the Simblee, then send CPU temperature
updates once a second.
This sketch works with SimbleeForMobile.
- Copyright (c) 2015 RF Digital Corp. All Rights Reserved.
- The source code contained in this file and all intellectual property embodied in
- or covering the source code is the property of RF Digital Corp. or its licensors.
- Your right to use this source code and intellectual property is non-transferable,
- non-sub licensable, revocable, and subject to terms and conditions of the
- SIMBLEE SOFTWARE LICENSE AGREEMENT.
- http://www.simblee.com/licenses/SimbleeSoftwareLicenseAgreement.txt
- THE SOURCE CODE IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND.
- This heading must NOT be removed from this file.
#include <SimbleeForMobile.h>
//#include "thermometer_png.h"
// this is the data we want to appear in the advertisement
// (if the deviceName and advertisementData are too long to fix into the 31 byte
// ble advertisement packet, then the advertisementData is truncated first down to
// a single byte, then it will truncate the deviceName)
SimbleeForMobile.advertisementData = "pulse";
// use a subdomain to create an application specific cache
//SimbleeForMobile.domain = "temp.Simblee.com";
// establish a baseline to use the cache during development to bypass uploading
// the image each time
//SimbleeForMobile.baseline = "Oct 23 2014";
// start SimbleeForMobile
SimbleeForMobile.begin();
bool first_sample;
int first_heartbeat;
//float min_heartbeat;
//float max_heartbeat;
//float heartbeat_range;
uint8_t text;
uint8_t heartbeat;
// include newlib printf float support (%f used in sprintf below)
asm(".global _printf_float");
// sample once per second
// todo: Simblee_ULPDelay( SECONDS(1) );
if (SimbleeForMobile.updatable)
// get a cpu temperature sample
// degrees c (-128.00 to +127.00)
// degrees f (-198.00 to +260.00)
// CELSIUS / FAHRENHEIT
float pulseValue = analogRead(3);
// requires newlib printf float support
char buf[16];
sprintf(buf, "%f", pulseValue);
// base everything on the first sample / ambient temperature
if (first_sample)
first_heartbeat = heartbeat;
// putting your finger on the Simblee shield raises the temp approx 2 degrees
min_temp = first_temp - 0.25;
max_temp = first_temp + 1.0;
temp_range = max_temp - min_temp;
first_sample = false;
// update the text first with the actual temp
SimbleeForMobile.updateText(text, buf);
// restrict temp to range
if (temp < min_temp)
temp = min_temp;
if (temp > max_temp)
temp = max_temp;
int mercury_range = 262;
int mercury_position = ((temp - min_temp) / temp_range) * mercury_range;
// invert so the smallest value at the bottom
mercury_position = mercury_range - (mercury_position);
// update the heartbeat
SimbleeForMobile.updateH(heartbeat, pulseValue/2);
// process must be called in the loop for SimbleeForMobile
SimbleeForMobile.process();
void SimbleeForMobile_onConnect()
first_sample = true;
void ui()
#define IMAGE1 1
SimbleeForMobile.beginScreen(WHITE);
// \xb0 is the symbol for "degrees"
SimbleeForMobile.drawText(280, 248, "/" "min", BLUE);
text = SimbleeForMobile.drawText(125, 240, "", BLUE, 30);
// usable area: 56, 136, 51, 262
// mercury area: 65, 136, 33, 262 + 15
heartbeat = SimbleeForMobile.drawRect(80, 120, 20, 20, rgb(252,135,0), rgb(252,30,0));
// hide the mercury until the image is uploaded
SimbleeForMobile.setVisible(heartbeat, false);
//SimbleeForMobile.imageSource(IMAGE1, PNG, thermometer_png, thermometer_png_len);
SimbleeForMobile.drawImage(IMAGE1, 30, 100);
SimbleeForMobile.setVisible(heartbeat, true);
SimbleeForMobile.endScreen();
void ui_event(event_t &event)
