Looking for help with ESP32
I want to take the Esp32 with sim800 and turn this into a Hot spot using a prepaid sim card, I have a wireless camera that I can view from my phone, The problem is the camera has to connect straight to internet, It will not work if connecting to internet via landing page, Where I need to place this camera the only wifi is belonging to one that uses a landing page, So I decided to use the ESp32 however it connects but without internet, I have checked the APN by placing the sim card in my tmobile phone, As far as I can tell it is correct. I have also tested to see if I am able to use the data side of the sim card and it worked, Here is the code I currently have
// Libraries which has to be installed
#define TINY_GSM_MODEM_SIM800      // Modem is SIM800 has to be defined before the Tiny-Include
#include <Wire.h>
#include <TinyGsmClient.h>
#include <WiFiClient.h>
#include <WiFi.h>
#include <WiFiServer.h>
// Variables and desired credentials.
const char *ssid     = "Hotspot Name";             // Access Point - SSID (Name)
const char *password = "123456789";            // Access Point - Password
const int APPort     = 8083;                 // Access Point -  Port
// Your GPRS credentials (leave empty, if missing)
const char apn[]      = "fast.t-mobile.com"; // GPRS - Your APN
const char gprsUser[] = "";                  // GPRS - User
const char gprsPass[] = "";                  // GPRS - Password
const char simPIN[]   = "1503";              // GPRS - SIM card PIN code, if any
// TTGO T-Call pin definitions
#define MODEM_RST            5
#define MODEM_PWKEY          4
#define MODEM_POWER_ON       23
#define MODEM_TX             27
#define MODEM_RX             26
#define I2C_SDA              21
#define I2C_SCL              22
#define SerialMonitor Serial          // Set serial for debug console to the Serial Monitor
#define SerialAT Serial1              // Set serial for AT commands (to the module)
#define TINY_GSM_RX_BUFFER   1024     // Set RX buffer to 1Kb
// #define TINY_GSM_DEBUG SerialMonitor // Define the serial console for debug prints
WiFiServer APserver(80);                 // neu für AP
TinyGsm modem(SerialAT);
TinyGsmClient Webclient(modem);
char server[] = "vsh.pp.ua";             // Server details of demo Website
// String resource = "/TinyGSM/logo.txt";
String resource = "/windows-version.txt";
const int  port = 80;                    // Port if demo Website
#define IP5306_ADDR          0x75
#define IP5306_REG_SYS_CTL0  0x00
bool setPowerBoostKeepOn(int en)
  Wire.beginTransmission(IP5306_ADDR);
  Wire.write(IP5306_REG_SYS_CTL0);
  if (en) {
    Wire.write(0x37); // Set bit1: 1 enable 0 disable boost keep on
    Wire.write(0x35); // 0x37 is default reg value
  return Wire.endTransmission() == 0;
  SerialMonitor.begin(115200);         // Set console baud rate
  SerialMonitor.println("Programm ESP32_TTGO_T_CALL_TinyGSM");  // Just to know which progm is running
  delay(10);
  WiFi.onEvent(WiFiEvent);             // set event-handler for WiFi
  WiFi.softAP(ssid, password);         // define credentials
  IPAddress myIP = WiFi.softAPIP();    // inform console about own IP-Adress
  SerialMonitor.print("AccessPoint IP address: ");
  SerialMonitor.println(myIP);
  SerialMonitor.print(":");
  SerialMonitor.print(APPort);
  APserver.begin(APPort);              // AccessPoint with defined Port
  SerialMonitor.println("WiFi Server started");
  // Keep power when running from battery
  Wire.begin(I2C_SDA, I2C_SCL);        // Workaround for Modem Power
  bool   isOk = setPowerBoostKeepOn(1);
  SerialMonitor.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
  pinMode(MODEM_PWKEY, OUTPUT);        // Set-up modem reset, enable, power pins
  pinMode(MODEM_RST, OUTPUT);
  pinMode(MODEM_POWER_ON, OUTPUT);
  digitalWrite(MODEM_PWKEY, LOW);
  digitalWrite(MODEM_RST, HIGH);
  digitalWrite(MODEM_POWER_ON, HIGH);
  // Set GSM module baud rate and UART pins
  SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
  delay(3000);
  SerialMonitor.println("Initializing modem...");
  //  modem.restart();                        // To skip it, call init() instead of restart()
  modem.init();                           // if you don't need the complete restart
  String modemInfo = modem.getModemInfo();
  SerialMonitor.print("ModemInfo: ");     // inform console about Modem info
  SerialMonitor.println(modemInfo);
  // Unlock your SIM card with a PIN if needed
  if (strlen(simPIN) && modem.getSimStatus() != 3 ) {
    modem.simUnlock(simPIN);
  SerialMonitor.print("Modemstatus: ");   // inform console about Modem info
  SerialMonitor.println(modem.getSimStatus());
  // Wenn ein WLAN - Client mit dem AP verbunden ist
  WiFiClient client = APserver.available();   // listen for incoming clients
  if (client) {                               // if you get a client,
    process(client);                        // Process request
    delay(10);
    client.stop();                          // Close connection and free resources.
    Serial.println("Client Disconnected.");
  }      // from if Client
}           // from loop()
void process(WiFiClient client) {
  Serial.println("New Session.");            // print a message out the serial port
  String currentLine = "";                   // make a String to hold incoming data from the client
  while (client.connected()) {               // loop while the client's connected
    if (client.available()) {                // if there's bytes to read from the client,
      char c = client.read();              // read a byte, then
      Serial.write(c);                     // print it out the serial monitor
      if (c == '\n') {                     // if the byte is a newline character
        // if the current line is blank, you got two newline characters in a row.
        // that's the end of the client HTTP request, so send a response:
        if (currentLine.length() == 0) {
          // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
          // and a content-type so the client knows what's coming, then a blank line:
          client.println("Content-type:text/html");
          client.println();
          // the content of the HTTP response follows the header:
          client.print("Klick <a href=\"/vsh.pp.ua\">here</a> to read sample page.<br>");
          // The HTTP response ends with another blank line:
          client.println();
          // break out of the while loop:
        } else {                // if you got a newline, then clear currentLine:
          currentLine = "";
      else if (c != '\r') {     // if you got anything else but a carriage return character,
        currentLine += c;       // add it to the end of the currentLine
      // Check to see if the client request was "GET //vsh.pp.ua":
      if (currentLine.endsWith(" HTTP/1.1")) {
        // First line of HTTP request looks like "GET /path HTTP/1.1"
        // Retrieve the "/path" part by finding the spaces or "/"
        int addr_start = currentLine.indexOf(' ');
        int addr_midl = currentLine.indexOf('/', addr_start + 2);
        int addr_end = currentLine.indexOf('HTTP');
        /*           SerialMonitor.print("addr_start:  ");
                     SerialMonitor.println(addr_start);
                     SerialMonitor.print("addr_midl:  ");
                     SerialMonitor.println(addr_midl);
                     SerialMonitor.print("addr_end:  ");
                     SerialMonitor.println(addr_end);
                     SerialMonitor.println();
                     SerialMonitor.print("currentLine:  ");
                     SerialMonitor.println(currentLine);     */
        String req_server = currentLine.substring(addr_start + 2, addr_midl);
        SerialMonitor.print("req_server.length():  ");
        SerialMonitor.println(req_server.length());
        SerialMonitor.println(req_server);
        if (req_server.length() == 0) {
          // No server defined -> Some Help
          client.println();
          client.print("Klick <a href=\"/vsh.pp.ua/TinyGSM/logo.txt\">here</a> um das Logo aufzurufen.<br>");
          client.println();
        String req_page = currentLine.substring(addr_midl, addr_end - 3);
        strcpy(server, req_server.c_str());
        resource = req_page;
        SerialMonitor.print("resource:  ");
        SerialMonitor.println(resource);
        SerialMonitor.print("Connecting to ");
        SerialMonitor.print(server);
        if (!Webclient.connect(server, port)) {
          SerialMonitor.println(" fail");
          delay(10000);
          return;
        SerialMonitor.println(" OK");
        // Make a HTTP GET request:
        SerialMonitor.println("Performing HTTP GET request...");
        Webclient.print(String("GET ") + resource + " HTTP/1.1\r\n");
        Webclient.print(String("Host: ") + server + "\r\n");
        Webclient.print("Connection: close\r\n\r\n");
        Webclient.println();
        unsigned long timeout = millis();
        while (Webclient.connected() && millis() - timeout < 10000L) {
          // Print available data
          while (Webclient.available()) {
            char c = Webclient.read();
            SerialMonitor.print(c);
            client.print(c);        // Ausgabe gleich auf den Client
            timeout = millis();
        // Verindung zum Web-Server abbauen
        Webclient.stop();
        SerialMonitor.println(F("Web-Server disconnected"));
void WiFiEvent(WiFiEvent_t event) {
  // Handler of WIFI-Event
  switch (event) {
    case SYSTEM_EVENT_WIFI_READY:
      Serial.println("SYSTEM_EVENT_WIFI_READY");
    case SYSTEM_EVENT_SCAN_DONE:
      Serial.println("SYSTEM_EVENT_SCAN_DONE");
    case SYSTEM_EVENT_STA_START:
      Serial.println("SYSTEM_EVENT_STA_START");
    case SYSTEM_EVENT_STA_STOP:
      Serial.println("SYSTEM_EVENT_STA_STOP");
    case SYSTEM_EVENT_STA_CONNECTED://or STARTED ?
      Serial.println("SYSTEM_EVENT_STA_CONNECTED");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      Serial.println("SYSTEM_EVENT_STA_DISCONNECTED");
    case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
      Serial.println("SYSTEM_EVENT_STA_AUTHMODE_CHANGE");
    case SYSTEM_EVENT_STA_GOT_IP:
      Serial.println("SYSTEM_EVENT_STA_GOT_IP");
    case SYSTEM_EVENT_STA_LOST_IP:
      Serial.println("SYSTEM_EVENT_STA_LOST_IP");
    case SYSTEM_EVENT_AP_START:
      Serial.println("SYSTEM_EVENT_AP_START");
    case SYSTEM_EVENT_AP_STOP:
      Serial.println("SYSTEM_EVENT_AP_STOP");
    case SYSTEM_EVENT_AP_STACONNECTED:
      Serial.println("SYSTEM_EVENT_AP_STACONNECTED");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      Serial.println("SYSTEM_EVENT_AP_STADISCONNECTED");
      modem.gprsDisconnect();
      SerialMonitor.println(F("GPRS disconnected"));
      // Do nothing forevermore
      SerialMonitor.println("www.thingsmobile.com user lora@felmayer.de");
    case SYSTEM_EVENT_AP_STAIPASSIGNED:
      Serial.println("SYSTEM_EVENT_AP_STAIPASSIGNED");
      // wenn eine WLAN-Verbindung aufgebaut ist !!!
      // Netzwerk initialisieren und Modem tiiii tööööö ti tit ti so wie bei alten Modem 14400 ...
      SerialMonitor.print("Waiting for network...");
      if (!modem.waitForNetwork(240000L)) {
        delay(10000);
        return;
      if (modem.isNetworkConnected()) {
        SerialMonitor.println("Network connected");
      SerialMonitor.print(F("Connecting to APN: "));
      SerialMonitor.print(apn);
      if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
        delay(10000);
        return;
    case SYSTEM_EVENT_AP_PROBEREQRECVED:
      Serial.println("SYSTEM_EVENT_AP_PROBEREQRECVED");
    default:
      Serial.println("UNKNOWN EVENT: " + event);
The WiFi you create in your ESP and what you do with the SIM are two different things, I don’t think there is an automatic routing like you get from a smartphone when you do internet sharing.
Just buy a 4G enabled wifi hotspots. I’m sure your carrier offers this.
I'm sorry I have a hard time explaining things, The esp32 comes with a sim slot , You can text from it , I want to use my sim in the ESp to create the access point
I understand this and I assume you want to be able to connect to your camera remotely
What I'm saying is that the data you receive from the WiFi part of your ESP32 is not routed to the SIM card even if you configured the SIM to to connect to the internet. (probably something you could envision programming with ESP IDF at lower level).
Also most SIM cards do not allow for direct incoming traffic (no static IP) without prior establishing an outgoing connexion.
There are professional 4G/5G + Wifi routers offering fixed IP capability. Messing around with Linux on a RPI with an external SIM based connexion could also be envisioned but requires a good understanding of routing.
BTW - If in the U.K. I have recently set up a wifi hotspot using a standard Three PAYG sim and cheap pocket hotspot device (adding a £10 a month data package) which works well.
Unlike many others, Three assign an IP address to the sim so I am able to connect to it using noip.com to supply a virtual fixed IP (DDNS). There is a library for updating noip.com from the ESP.
