Hello,
Im looking for different sensors/moduls which can be used in high ambient temperatures (~120-150°C)
- Air pressure sensor
- Temperature array
- Air temperature sensor
- Wifi module
Do you have any suggestions?
Hello,
C or F?
thanks for your reply,
°C
Regarding the Temperature array: Im looking for something similar to MLX90621.
JoE1205:
Hello,Im looking for different sensors/moduls which can be used in high ambient temperatures (~120-150°C)
- Temperature array
- Wifi module
Don't you by any chance forget about the Arduino or other microprocessor? It sounds to me like you want to use your compete project at that temperature - why is that? What is is that you're trying to do?
High temperature versions of chips (look for the automotive versions) typically max out at 135° which is in the middle of your range.
