Looking for Laser Rotational Sensor
I am looking for a Laser Rotational sensor like used for the Digital Laser Tach in the link below
I want to use just the sensor for a arduino based project, but have not been able to find it.
I want to read the rpm of a wheel that has reflective tape, that may be 3 inches away. I am using the digital tach, but want to be able to read into an arduino and log it.
Such a tachometer is not very different from any other optical (reflective) light barrier. Replace the LED by a laser diode, and you're almost done. The receiver should be sensitive to the laser frequency, any phototransistor should work.
The sharp dot, produced by a laser diode, requires exact adjustment of the reflector, i.e. the reflected beam must hit the receiver.
