I'm looking for a lightweight True Random Number Generator for a NodeMCU 12e. I was using this code for an earlier version of the IDE, but now it throws an error.
unsigned long x1 = 123456789,
y1 = 234567891,
z1 = 345678912,
w1 = 456789123,
c1 = 0;
unsigned long JKISS32 (int a, int b) {
long t;
y1 ^= y1 << 5;
y1 ^= y1 >> 7;
y1 ^= y1 << 22;
t = z1 + w1 + c1;
z1 = w1;
c1 = t < 0;
w1 = t & 2147483647;
x1 += 1411392427;
//return (x1 + y1 + w1);
return (x1 + y1 + w1) / (4294967294 / (b - a + 1)) + a ;
void SeedJKISS32 (const unsigned long newseed) {
if (newseed != 0) {
x1 = 123456789;
y1 = newseed;
z1 = 345678912;
w1 = 456789123;
c1 = 0;
the error is "'long unsigned int y1' redeclared as different kind of symbol". Any help greatly appreciated
What is your definition of a true random number generator? The only TRNG are those which extract values from white noise. The closest you come to this on the Arduino is with analogRead from an unconnected analog pin.
I use the Two Least Sign algorithm with a von Neumann corrector.
Again, this is code that worked with an earlier version of Arduino IDE
Again, that is a snippet of code. Post the COMPLETE code.
Removing the declaration of y1 as an unsigned long now makes it look like y1 is declared somewhere as a double, and left shifting a double doesn't make sense.
Even this code alone returns the error "'long unsigned int y1' redeclared as different kind of symbol"
unsigned long x1 = 123456789;
unsigned long y1 = 234567891;
unsigned long z1 = 345678912;
unsigned long w1 = 456789123;
unsigned long c1 = 0;
Compiles OK for me
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
The full error messages give the reason. In hardware/esp8266/2.4.1/tools/sdk/libc/xtensa-lx106-elf/include/math.h:475:15: error: previous declaration of 'double y1(double)'
extern double y1 _PARAMS((double));
So the math.h for the NodeMCU is declaring a function called y1.
Build options changed, rebuilding all
sketch_aug25a:3: error: 'long unsigned int y1' redeclared as different kind of symbol
y1 = 234567891,
In file included from /Users/john/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.1/cores/esp8266/Arduino.h:34:0,
from sketch/sketch_aug25a.ino.cpp:1:
/Users/john/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.1/tools/sdk/libc/xtensa-lx106-elf/include/math.h:475:15: error: previous declaration of 'double y1(double)'
/Users/john/Documents/Arduino/sketch_aug25a/sketch_aug25a.ino: In function 'long unsigned int JKISS32(int, int)':
sketch_aug25a:11: error: invalid operands of types 'double(double)' and 'int' to binary 'operator<<'
y1 ^= y1 << 5;
sketch_aug25a:12: error: invalid operands of types 'double(double)' and 'int' to binary 'operator>>'
y1 ^= y1 >> 7;
sketch_aug25a:13: error: invalid operands of types 'double(double)' and 'int' to binary 'operator<<'
y1 ^= y1 << 22;
/Users/john/Documents/Arduino/sketch_aug25a/sketch_aug25a.ino:20:16: warning: pointer to a function used in arithmetic [-Wpointer-arith]
/Users/john/Documents/Arduino/sketch_aug25a/sketch_aug25a.ino:20:21: warning: pointer to a function used in arithmetic [-Wpointer-arith]
sketch_aug25a:20: error: invalid operands of types 'double (*)(double)' and 'long long int' to binary 'operator/'
/Users/john/Documents/Arduino/sketch_aug25a/sketch_aug25a.ino: In function 'void SeedJKISS32(long unsigned int)':
sketch_aug25a:28: error: assignment of function 'double y1(double)'
y1 = newseed;
sketch_aug25a:28: error: cannot convert 'const long unsigned int' to 'double(double)' in assignment
/Users/john/Documents/Arduino/sketch_aug25a/sketch_aug25a.ino:21:1: warning: control reaches end of non-void function [-Wreturn-type]
exit status 1
Would this be faster then my method? it's all about speed in this case. Also, how could I apply this method to a range of numbers? ex. a random number between 0 and 10
This has bitten me before. It turns out that “y1” is a standard libc math function. (Also y0, j0, and a couple more that you wonder how they got such lousy names.)
If you work with Bessel functions, then it is quite obvious to want functions named something like j0, y1, etc. as these are centrally important. The authors should have used upper case (J0) in the names, though.
Yeah, well, given they wanted to add a relatively obscure math function, and given the choice between breaking the common style rule that says "uppercase names are for macros, not for function names", and breaking nearly every graphics program ever written, the obviously made the correct decision!
