Hello, can anyone recommend a small scale reliable manufacturer that can take a breadboard prototype and convert it into an enclosed pcb? I tried working with someone on fivrr but it ended up being a waste of time, so a reputable person or company that could move reasonably quickly is what I'm after.
If details matter, it's a small pcb (maybe 4 by 6 inches) with approximately 20 i/os to a pin header. I'm guessing it'll be around a 50 item order after proof of concept? Any caution, advice or suggestions would be appreciated as this is my first time doing this.
Actually, a reputable company would not ever touch such a project! You get the circuit board ready to go, after many tries, and then a reputable company will reproduce your product as many time as you want.
You might want to also consider a solderable breadboard like this. NOTE this is amazon.ca so change country as appropriate https://www.amazon.ca/dp/B06ZY75TWX
I have worked for engineering services companies and I also do freelance development. I don’t know that I’ve ever come across an established business that will take a breadboard and convert it to a packaged unit.
Generally you will approach them with a concept or a design in mind, and they do the whole thing. The problem with starting from a breadboard is that you still have to provide a list of requirements that the final product must satisfy. After all, they could faithfully reproduce your circuit on a PCB and if it doesn’t work, fingers are now pointing at each other. Perhaps the design never worked in the first place? Perhaps it was just barely working, and now that it’s moved to a different substrate, conditions are different, so now it’s not working any more.
When you start with a set of requirements, it’s on them to get everything right. If something goes wrong, then it’s clearly their error and they have to fix it.
This is pretty much the same reason that most auto repair shops don’t want to deal with customer-supplied parts.
Ok, apparently I should have phrased that differently. The breadboard is a reference for me to help me decide on and work through the requirements that I would like to provide to them.
I would prefer they did their own design from scratch, as they know what they're doing and I do not.
